I’m new to Openhab2, coming from a working Jeedom installation. After struggling a little bit with discovery (a lot of “unknow device”…), I think I have all my device ready to work…
But my roller shutter zawave module, (Fibaro FGRM 222) doesn’t work as expected: commands are inverted (up is down and vice versa)… How to set this up? This is not clear…
My OH2 setup is based on a snapshot release (downloaded a few days ago), running in a Docker container, on one of my RPi 2.
Also note a=that every thing was working smoothly and as expected with Jeedom, so I should need to invert my roller shutter switch wires.
Hi, just a complementary question about this: if I want to declare my item in a *.items file. How should I do?
It’s unclear what to choose between these two syntaxes:
Rollershutter Shutter_GF_Kitchen “Kitchen [%d %%]” (GF_Kitchen, Shutters) {zwave="??:??:command=??,invert_state=false,invert_percent=true"}
And
Rollershutter Shutter_GF_Kitchen “Kitchen [%d %%]” (GF_Kitchen, Shutters) { channel=“zwave:device:??:??:switch_dimmer” } (and in this case, where should I define invert_* configuration options?)
I’ve read the doc, and to say the least, it’s not obvious
