Dear all,
I am trying to configure my roller shutters in OpenHab1. Due to the testing, based on manual switches.
As I am not so skilled in defining the rules, I am working in an agile fashion, starting with very simple functionality, which is up and down based on sunset and sunrise, an override/disable function and implement different scopes for weekdays and weekends, later incl. public holidays. Movement only in a certain time window, like between 7 and 11pm will implemented later. Additionally, I am looking for a solution, to move each shutter with a random delay, where the order is allowd to change. Maybe someone can advise how to achieve this too and if this approach makes sense or not.
Currently I am struggling with the override, which is a switch, to disable the rules.
If this rule runs incl. the override switch:
rule "Rollos Hoch"
Item Event_Sonnenaufgang1 received update ON
if(now.getDayOfWeek <= 5) //&& // Montag bis Freitag
if(HM_Fenster_Automodus.state != OFF){
HM_Fenster_Arbeitszimmer.sendCommand(UP)
I got this this error:
2017-02-21 13:12:04.157 [ERROR] [o.o.c.s.ScriptExecutionThread ] - Error during the execution of rule 'Rollos Hoch': Ambiguous methods [protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateReturnExpression(org.eclipse.xtext.xbase.XReturnExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateStringLiteral(org.eclipse.xtext.xbase.XStringLiteral,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateSwitchExpression(org.eclipse.xtext.xbase.XSwitchExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateThrowExpression(org.eclipse.xtext.xbase.XThrowExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateTryCatchFinallyExpression(org.eclipse.xtext.xbase.XTryCatchFinallyExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateTypeLiteral(org.eclipse.xtext.xbase.XTypeLiteral,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateVariableDeclaration(org.eclipse.xtext.xbase.XVariableDeclaration,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateWhileExpression(org.eclipse.xtext.xbase.XWhileExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateAbstractFeatureCall(org.eclipse.xtext.xbase.XAbstractFeatureCall,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateAssignment(org.eclipse.xtext.xbase.XAssignment,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateBlockExpression(org.eclipse.xtext.xbase.XBlockExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateBooleanLiteral(org.eclipse.xtext.xbase.XBooleanLiteral,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateCastedExpression(org.eclipse.xtext.xbase.XCastedExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateClosure(org.eclipse.xtext.xbase.XClosure,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateConstructorCall(org.eclipse.xtext.xbase.XConstructorCall,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected org.eclipse.xtext.xbase.interpreter.IEvaluationResult org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateDoWhileExpression(org.eclipse.xtext.xbase.XDoWhileExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateForLoopExpression(org.eclipse.xtext.xbase.XForLoopExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateIfExpression(org.eclipse.xtext.xbase.XIfExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateInstanceOf(org.eclipse.xtext.xbase.XInstanceOfExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateMemberFeatureCall(org.eclipse.xtext.xbase.XMemberFeatureCall,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateNullLiteral(org.eclipse.xtext.xbase.XNullLiteral,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateNumberLiteral(org.eclipse.xtext.xbase.XNumberLiteral,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator)] for params [null, org.eclipse.xtext.xbase.interpreter.impl.DefaultEvaluationContext@1d255fd, org.eclipse.xtext.util.CancelIndicator$1@51ef5c]
I have no clue, what this error should tell me?! If I remove the override clause “HM_Fenster_Automodus.state” everything is fine.
Thanks and regards
Manuel
