I have a Zemismart curtain motor ( SK-3007-05 ) that I added entirely through OH3 UI and I don’t use an items file for but I find it has the UP/DOWN reversed.
The motor itself was reversed when when I first set it up with the included remotes and I reversed it using the remote sequence described in the manual before I included the z wave device into OH3. I believe it may need to get reversed if the motor goes on left vs right side of the window.
Now I find the UP / DOWN commands when sent from a sitemap to be backwards. For example, I hit the “DOWN” button in the sitemap and the following logs appear:
Item 'CurtainMotor1_BlindsControl' received command DOWN
Item 'CurtainMotor1_BlindsControl' predicted to become DOWN
Item 'CurtainMotor1_BlindsControl' changed from 100 to 0
The curtains get opened and the sitemap icon appears open but DOWN should be the close command.
I also have a rule that sends an UP command but it closes instead of opens them and vice versa.
I see that there is Set motor direction
setting in the thing config screen and it was 0 and I’m trying 1(?) but I suspect that may reverse the remote setting and not the zwave setting.
