- Platform information:
- Hardware: RPI4
- OS: openhabian
- openHAB version: 2.5.2
Issue:
I have rollershutters within my system. I am using Slider and/ or Switch elements to control them.
Example Item:
Rollershutter DG_Atelier_Rollershutter_p "" <none> (DG_Atelier, gShutter, gShutterP {channel="freeathome:raffstore:8cc0094d:percentage"}
Example in Sitemap:
Slider item=DG_Atelier_Rollershutter_p label="Atelier (Garage)" icon="rollo"
Icons in icons/classic:
From openhab-cli console
openhab> items list | grep gShutterP
EG_LivingRoom_Rollershutter_TL_p (Type=RollershutterItem, State=100.0, Label=, Category=none, Groups=[EG_LivingsRoom, gShutter, gShutterP])
DG_Bedroom_Rollershutter_Right_p (Type=RollershutterItem, State=100, Label=, Category=none, Groups=[DG_Bedroom, gShutter, gShutterP])
OG_Kinderspielzimmer_Rollershutter_p (Type=RollershutterItem, State=100.0, Label=, Category=none, Groups=[OG_Kinderspielzimmer, gShutter, gShutterP])
DG_Atelier_Rollershutter_Terasse_p (Type=RollershutterItem, State=100.0, Label=, Category=none, Groups=[DG_Atelier, gShutter, gShutterP])
OG_Kinderschlafzimmer_Rollershutter_p (Type=RollershutterItem, State=100, Label=, Category=none, Groups=[OG_Kinderschlafzimmer, gShutter, gShutterP])
gShutterP (Type=GroupItem, BaseType=NumberItem, Members=14, State=0.96428571, Label=Rollo State, Category=null)
OG_Arbeitszimmer_Rollershutter_p (Type=RollershutterItem, State=100.0, Label=, Category=none, Groups=[OG_Arbeitszimmer, gShutter, gShutterP])
DG_Atelier_Rollershutter_p (Type=RollershutterItem, State=100, Label=, Category=none, Groups=[DG_Atelier, gShutter, gShutterP])
EG_Eating_Rollershutter_p (Type=RollershutterItem, State=100, Label=, Category=none, Groups=[EG_LivingsRoom, gShutter, gShutterP])
EG_Toilet_Rollershutter_p (Type=RollershutterItem, State=100, Label=, Category=none, Groups=[EG_Toilet, gShutter, gShutterP])
EG_LivingRoom_Rollershutter_TR_p (Type=RollershutterItem, State=100.0, Label=, Category=none, Groups=[EG_LivingsRoom, gShutter, gShutterP])
DG_Bedroom_Rollershutter_Left_p (Type=RollershutterItem, State=50.0, Label=, Category=none, Groups=[DG_Bedroom, gShutter, gShutterP])
OG_Kinderschlafzimmer_Rollershutter_Garage_p (Type=RollershutterItem, State=100, Label=, Category=none, Groups=[OG_Kinderschlafzimmer, gShutter, gShutterP])
EG_Kitchen_Rollershutter_p (Type=RollershutterItem, State=100, Label=, Category=none, Groups=[EG_Kitchen, gShutter, gShutterP])
OG_Bathroom_Rollershutter_p (Type=RollershutterItem, State=100.0, Label=, Category=none, Groups=[OG_Bathroom, gShutter, gShutterP])
As you can see there are sometimes values = 100.0 and sometimes it’s 100. And that leads to sometimes icons that work and sometimes it’s not working, depending on the number format of the value field, where 100.0 is with correct icon and 100 is w/o correct item.
I also tried using a Slider element with the following extras: minValue=0.0 maxValue=100.0 step=0.5
But also then it defaults to 0 or 100 instead of 0.0 and 100.0 and therefore does not show the right icon.
Any suggestions what I can do to enforce the right numeric value (double)?
Edit: I just checked… in classic UI (web, chrome) it is working fine, my issues seems to be related to the iOS app?
Thanks and best,
David
