openHAB version: 5.2.0.M4
Binding: MQTT Binding with Zigbee2MQTT
Problem
I have rollershutter groups that also contain other item types (Switch, Number, Dimmer). Because of this, I cannot use Group:Rollershutter for the sub-groups, since that would prevent UP/DOWN/STOP commands from being accepted when other item types are members.
To work around this, I use two separate groups: one plain Group for the sitemap structure, and one Group:Rollershutter purely for the command forwarding.
My current configuration
groups.items:
// Plain group for sitemap structure (Switch, Slider, sub-groups)
Group Group_GF_Livingroom_Rollershutter "Wohnzimmer Rollos" <rollershutter>
(Group_GF_Livingroom) ["Control"]
// Typed group for UP/DOWN/STOP command forwarding
Group:Rollershutter Group_GF_Livingroom_Rollershutter_Function "Wohnzimmer Rollos" <rollershutter>
// AVG position group for the position slider
Group:Number:AVG Group_GF_Livingroom_RollershutterPosition "Wohnzimmer Position [%.0f %%]" <rollershutter>
zigbee.items — sub-groups (plain Group, contain mixed item types):
Group Group_GF_Livingroom_RollershutterOne (Group_GF_Livingroom_Rollershutter) ["Control"]
Group Group_GF_Livingroom_RollershutterTwo (Group_GF_Livingroom_Rollershutter) ["Control"]
zigbee.items — Rollershutter items (member of BOTH sub-group AND function group):
Rollershutter Rollershutter_GF_Livingroom_DoorCoveringOne "..."
(Group_GF_Livingroom_RollershutterOne, Group_GF_Livingroom_Rollershutter_Function) ["OpenLevel"] {
channel="mqtt:topic:zigbee:rollershutterLivingRoomDoor1Rollershutter"
[profile="transform:JS", toItemScript="| 100 - Number(input)", commandFromItemScript="| 100 - Number(input)"]
Rollershutter Rollershutter_GF_Livingroom_DoorCoveringTwo "..."
(Group_GF_Livingroom_RollershutterTwo, Group_GF_Livingroom_Rollershutter_Function) ["OpenLevel"] {
channel="mqtt:topic:zigbee:rollershutterLivingRoomDoor2Rollershutter"
// Position as separate Dimmer item with inverted value
Dimmer Position_GF_Livingroom_DoorCoveringOnePosition "..." <rollershutter>
(Group_GF_Livingroom_RollershutterOne, Group_GF_Livingroom_RollershutterPosition, ...) ["Control"] {
channel="mqtt:topic:zigbee:numberLivingRoomDoor1RollershutterPosition"
mqtt.things — Rollershutter channel:
Type rollershutter : rollershutterLivingRoomDoor1Rollershutter "..." [
stateTopic="zigbee2mqtt/0xAABBCCDDEEFF0001",
transformationPattern="JSONPATH:$.position",
commandTopic="zigbee2mqtt/0xAABBCCDDEEFF0001/set",
stop="{\"state\": \"STOP\"}",
formatBeforePublish="{\"state\":%s}",
off="{\"state\": \"CLOSE\"}",
on="{\"state\": \"OPEN\"}"
sitemap:
Group item=Group_GF_Livingroom_Rollershutter label="Wohnzimmer Rollos" icon="rollershutter"
Switch item=Group_GF_Livingroom_Rollershutter_Function label="Alle Rollos" mappings=[UP="▲", STOP="■", DOWN="▼"]
Slider item=Group_GF_Livingroom_RollershutterPosition label="Alle Position [%.0f %%]" icon="rollershutter" minValue=0 maxValue=100 step=1
Group item=Group_GF_Livingroom_RollershutterOne label="Rollo 1" icon="rollershutter"
Default item=Rollershutter_GF_Livingroom_DoorCoveringOne label="Rollo"
Slider item=Position_GF_Livingroom_DoorCoveringOnePosition label="Position [%.0f %%]" icon="rollershutter" minValue=0 maxValue=100 step=1
Switch item=Switch_GF_Livingroom_DoorCoveringOneBacklight label="Hintergrundbeleuchtung"
Switch item=Switch_GF_Livingroom_DoorCoveringOneCalibration label="Kalibrierung"
Text item=Sensor_GF_Livingroom_DoorCoveringOneLinkQuality label="Verbindungsqualität"
Group item=Group_GF_Livingroom_RollershutterTwo label="Rollo 2" icon="rollershutter"
Default item=Rollershutter_GF_Livingroom_DoorCoveringTwo label="Rollo"
Slider item=Position_GF_Livingroom_DoorCoveringTwoPosition label="Position [%.0f %%]" icon="rollershutter" minValue=0 maxValue=100 step=1
Switch item=Switch_GF_Livingroom_DoorCoveringTwoBacklight label="Hintergrundbeleuchtung"
Switch item=Switch_GF_Livingroom_DoorCoveringTwoCalibration label="Kalibrierung"
Text item=Sensor_GF_Livingroom_DoorCoveringTwoLinkQuality label="Verbindungsqualität"
Background / Reason for inversion
Zigbee2MQTT reports position: 0 = fully closed and position: 100 = fully open, which is the opposite of openHAB’s convention (0% = open, 100% = closed). I use inline JS transformation to invert the value in both directions:
Questions
- Is the two-group approach (
Groupfor structure +Group:Rollershutterfor command forwarding) the correct/recommended way to handle groups with mixed item types?
Thanks in advance!
