I set up goups and items for rollershutters in an items file.
Whereas the groups/items with a zwave device are working just fine, the MQTT items don’t work despite identical configuration:
Zwave:
Group gEG_Wohnzimmer_Rollo_Tuer "Terassentür" {alexa="Endpoint.ExteriorBlind"}
Rollershutter EG_Wohnzimmer_Rollo_Tuer "Rollo Wohnzimmer Tür [%s %%]" <rollershutter> (gEG_Wohnzimmer_Rollos, gEG_Wohnzimmer_Rollo_Tuer) {channel="zwave:device:51d851b7:node10:blinds_control", alexa="RangeController.rangeValue" [category="EXTERIOR_BLIND", friendlyNames="@Setting.Opening", supportedRange="0:100:10", unitOfMeasure="Percent", actionMappings="Close=100,Open=0,Lower=(-10),Raise=(+10)", stateMappings="Closed=100,Open=0:99"]}
MQTT:
Group gOG_Buero_Rollo "Rollo Jörg" {alexa="Endpoint.ExteriorBlind"}
Rollershutter OG_Buero_Rollo "Rollo Büro [%s %%]" <rollershutter> (gOG_Buero, gOG_Buero_Rollo, gShutter)
{mqtt=">[mosquitto:Haus/OG/Buero/Rollo/cmnd/SHUTTEROPEN1:command:UP:1],>[mosquitto:Haus/OG/Buero/Rollo/cmnd/SHUTTERCLOSE1:command:DOWN:1],>[mosquitto:Haus/OG/Buero/Rollo/cmnd/SHUTTERSTOP1:command:STOP:1]",
alexa="RangeController.rangeValue" [category="EXTERIOR_BLIND", friendlyNames="@Setting.Opening", supportedRange="0:100:10", unitOfMeasure="Percent", actionMappings="Close=0,Open=100,Lower=(-10),Raise=(+10)", stateMappings="Closed=0,Open=1:100"]}
Any hints appreciated
Joerg
