Thank you
Is that what you mean?
2019-12-27 15:51:41.231 [vent.ItemStateChangedEvent] - Win_on1 changed from ON to OFF
2019-12-27 15:51:43.053 [ome.event.ItemCommandEvent] - Item ‘Win_off’ received command ON
2019-12-27 15:51:43.224 [vent.ItemStateChangedEvent] - Win_off changed from OFF to ON
2019-12-27 15:51:43.228 [WARN ] [eneric.internal.generic.ChannelState] - Command ‘ON’ not supported by type ‘RollershutterValue’: null
2019-12-27 15:51:43.257 [ome.event.ItemCommandEvent] - Item ‘Win_off’ received command ON
2019-12-27 15:51:43.323 [WARN ] [eneric.internal.generic.ChannelState] - Command ‘ON’ not supported by type ‘RollershutterValue’: null
2019-12-27 15:51:46.157 [ome.event.ItemCommandEvent] - Item ‘Win_off’ received command OFF
2019-12-27 15:51:46.223 [WARN ] [eneric.internal.generic.ChannelState] - Command ‘OFF’ not supported by type ‘RollershutterValue’: null
2019-12-27 15:51:46.233 [vent.ItemStateChangedEvent] - Win_off changed from ON to OFF
2019-12-27 15:51:51.613 [ome.event.ItemCommandEvent] - Item ‘Win_on1’ received command OFF
2019-12-27 15:51:51.646 [WARN ] [eneric.internal.generic.ChannelState] - Command ‘OFF’ not supported by type ‘RollershutterValue’: null
2019-12-27 15:51:57.263 [ome.event.ItemCommandEvent] - Item ‘Win_off’ received command OFF
2019-12-27 15:51:57.311 [WARN ] [eneric.internal.generic.ChannelState] - Command ‘OFF’ not supported by type ‘RollershutterValue’: null
14:48:50 MQT: stat/windows/POWER1 = ON
14:48:53 MQT: stat/windows/RESULT = {“POWER1”:“OFF”}
14:48:53 MQT: stat/windows/POWER1 = OFF
14:48:57 MQT: stat/windows/RESULT = {“POWER1”:“OFF”}
14:48:57 MQT: stat/windows/POWER1 = OFF
14:48:59 MQT: stat/windows/RESULT = {“POWER2”:“OFF”}
14:48:59 MQT: stat/windows/POWER2 = OFF
14:49:04 MQT: stat/windows/RESULT = {“POWER1”:“OFF”}
14:49:04 MQT: stat/windows/POWER1 = OFF
