Hallo!
Ich use the roller shutter item in my setup and a number item to check the value…
Rollershutter RollershutterItem "Roller shutter position [%d %%]" (gArbeitszimmer){modbus="<[shutterposition:11],>[testbit:0:trigger=UP,transformation=1],>[testbit:1:trigger=DOWN,transformation=1],>[testbit:0:trigger=STOP,transformation=0],>[testbit:1:trigger=STOP,transformation=0]"} //,>[testbit:2:trigger=MOVE,transformation=1],>[testbit:2:trigger=STOP,transformation=0]"}
Number RollershutterTest "Test [%d °C]" <temperature> (gArbeitszimmer){modbus="<[shutterposition:11]"}
The value of the number item is always right! But the roller shutter position is “0” or “100” independent on the correct value and it changes with pressing the up or down button. The input is a UINT16 between 0…100. From docs I know that the input for roller shutter position should be between 0…100 but I also tested 0…1 without success.
Where is my failure?
Sprocky
