I am new to OH (running 3.2.0 with OpenHABian on x86 hardware) and I am trying to migrate my devices from another platform to OH. I started by adding my Fibaro Walli Rollershutter (FIBEFGWREU-111) devices using an Aeotec Z-Stick 5+. Technically everything works fine (I guess…)
- Z-Wave Device was added as Thing to OH
- Used “Add Equipment to Model” in Thing Channels
- Equipment created an Item with several Points in my Model. One is ff_of_rollershutter_control, which is the rollershutter Control. I then added an additional Point ff_of_rollershutter_position as Dimmer, the get/set a position as percentage value.
The problem however is the following:
When moving, the position is not updated in real-time in the Dimmer, when movement is stopped, position is updated after some delay. Is there a chance to get a real-time position update (i.e. every 1s when moving)?
When it is fully opened or fully closed the position value is not updated at all. It remains the last value were it was stopped.
Example: Blinds were stopped at 55 % and command UP was sent; this is what I can see in events.log:
2022-06-26 18:49:21.357 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'ff_of_rollershutter_control' received command UP
2022-06-26 18:49:21.360 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'ff_of_rollershutter_control' predicted to become UP
2022-06-26 18:49:21.365 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ff_of_rollershutter_control' changed from 55 to 0
2022-06-26 18:49:21.947 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ff_of_rollershutter_electricmeter_watts' changed from 116.3 to 0
2022-06-26 18:49:22.102 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ff_of_rollershutter_position' changed from 55 to 59
2022-06-26 18:49:22.103 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ff_of_rollershutter_control' changed from 0 to 59
2022-06-26 18:49:24.814 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ff_of_rollershutter_electricmeter1_watts' changed from 0 to 98.6
Note: “changed from 55 to 0” → 0 was the position before the 55 (blinds were fully closed). Now as it starts moving, there is one single update → value = 59.
When fully opened, it should have position value = 100, but this is never coming to OH, at least it is not shown in events.log.
When I now trigger a full close, the following happens:
2022-06-26 18:53:02.573 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'ff_of_rollershutter_control' received command DOWN
2022-06-26 18:53:02.576 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'ff_of_rollershutter_control' predicted to become DOWN
2022-06-26 18:53:02.580 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ff_of_rollershutter_control' changed from 59 to 100
2022-06-26 18:53:03.516 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ff_of_rollershutter_position' changed from 59 to 95
2022-06-26 18:53:03.517 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ff_of_rollershutter_control' changed from 100 to 95
2022-06-26 18:53:06.111 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ff_of_rollershutter_electricmeter1_watts' changed from 0 to 116.4
2022-06-26 18:53:25.891 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ff_of_rollershutter_electricmeter1_watts' changed from 116.4 to 0
As you can see here, the first update is the value it had when starting (100), which was never set in OH before. Next update is then a first position update (95). The full close state however is never received.
Additional info: the position value is updated, when I press the stop button afterwards.
Any idea on this? Is there some mis-configuration in my Things, Items, what ever?
Thanks and regards from Germany
Markus
