I’m in the migration from OH 1 to OH2.
Most works fine, but I get some strange messages
2016-11-24 18:50:58.017 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate command ‘DOWN’ for item ‘Jal_Kinderzimmer’ to handler for channel ‘zwave:device:d0edbbe8:node3’, because no thing with the UID ‘zwave:device:d0edbbe8’ could be found.
I also tried to configure my FGRM222 through text files and could not get it to work. Since I use Habmin configured items and things they work … I gave the items the same name so I did not have to change my rules.
I suspect that something is wrong with your definitions somewhere since the error seems correct in that the thing doesn’t exist. I don’t know what causes the error - ie what are you doing when it happens? Is it from a sitemap or what?
