Rollershutter with Alexa inverted
(Giorgio) #1
I created an item for my zwave rollershutter as Dimmer
Dimmer Serranda_Cucina_Alexa "Serranda cucina" ["Lighting"] {channel="<mydeviceif>:node5:blinds_control"}
But when I use with Alexa the command are inverted.
For example if I say Alexa close the Serranda Cucina it open it…
How can I revert the use?
(SiHui) #2
There is an option in the blinds_control channel named “invert percentage”
(Giorgio) #3
Thank you for the answer,
yes I used it before because I inverted it, but creating a new items only for Alexa using that channel, isn’t possible to customize that item (without making a custom role)
(SiHui) #4
Not that I know of. I am using it this way:
Rollershutter FibFGR222_Kitchen_East "Küche Ost [%d %%]" { channel="zwave:device:uzb:node11:blinds_control" }
Dimmer FibFGR222_Kitchen_East_Alexa "Küche Ost" [ "Lighting" ]
rule "Jalousie Küche Ost"
	Item FibFGR222_Kitchen_East_Alexa received command
	FibFGR222_Kitchen_East.sendCommand(FibFGR222_Kitchen_East_Alexa.state.toString)
(Giorgio) #5
If in the Dimmer I don’t put a channel Alexa answer me “the item isn’t answering”
(SiHui) #6
You need to search for new devices on Alexa so it picks up the changes.
