The version of MQTT binding is 2.4.0. When I press Stop, in OH Log, says something as: STOP is not a command for rollershuter.(I’m not in front of computer)
But in openHAB, 0% for a rollershutter represents “open”
Yes, MQTT binding 2.4 had poor support for rollershutter types. It’s been improved for 2.5 - though I believe it is still a bit quirky.
If it were me, I think I would code around this for now, until the binding gets sorted.
I’d remove the commandTopic from the MQTT thing, and make a rule triggered from UI command that directly sent what you want as MQTT Actions.
Unrelated, isn’t there a position state reporting topic you could listen for, instead of Power1?
Thanks for your reply.
I will try to do as you mentioned, but I thought that with the fork of Tasmota it was easy than make a rules for this. With the inconvenient that I am beginner. and costs me a lot do this things.
Finally, I tried to put Tasmota again and I solved. Now I have the roller shutters working.
rule "Persiana derecha Ático subir"
Time cron "0 30 09 1/1 * ? *"
AticodchaUpDown.sendCommand(100)
rule "Persiana derecha Ático bajar"
Time cron "0 00 20 1/1 * ? *"
AticodchaUpDown.sendCommand(0)
