first post here, so plz be gentle
Most part of my house is configured with KNX (switch, dimmer, shutters, LED-RGB, RTR, Weather station…) and works for over about 2 years. I want to use openhab mainly for visualization of the KNX setup on mobile devices at first and maybe in later stage for further automation.
I’m a OH newbee, but read a good part of the docs and did lots of searches on this forum. I have openhab2.4.0-1 running on a RaspberryPi and use Visual Codec Studio since some time. I’ve been playing with it and I can get most things working on a small scale (KNX binding, 1 light on/off, making 1 temperature visible); this both using PaperUI and manual text files. so far so good
My questions is now: What is the easiest and most efficient way to put all KNX config into OH files?
I tried with HomeBuilder to create sitemap, items files and Dashboard. However How to create the things file from there?
I also started to put some KNX actors and channels in the things file and somehow to make a link with the Homebuilder created files. None of the above ways really seem efficient
so If you had to start all over from KNX to OH, what different steps would you take? where to start? which files first? what kind of logic do you build in the config files?
many thanks
Denhertog
Release = Raspbian GNU/Linux 10 (buster)
