ROTO I8 R8 automation
Hi all,
I anybody out there who managed to connect Roto Windows (I8 R8) to Openhab via KNX or similar?
What (Comunication-) Hardware and Binding is needed?
Thank you in advance.
-Dieter
Did you ask the manufacturers if there is integration to existing home automation systems?
Did you check the Home Assistant forum?
Looks like Roto works with Becker CentralControl. They mention it on the WebSite. Is OpenHAB able to connect to this Hub?
