Route traffic calculation based on Bing maps
I found some interesting code snippets, which allows you to check the estimated travel time to your work, or any other route.
netcscaler.expert’s blog entry
The only problem is, that bing maps is limited to 125000 Requests a year.
Therefore i want to switch to google maps api.
By the way, if you plan to use it, you can define the cronjob without a shell script,
directly in the rules section:
rule "Cron 10 Minutes"
	Time cron "0 */10 * * * ?"
	executeCommandLine("php /configurations/scripts/route.php")
Sounds very nice, ill implement this too.
@sptzdmnc but when you use google api it doesn’t use in time traffic information, does it?
Google only seems to offer it on it’s business API.
Depending on where you live, there is another alternative:
TomTom’s api (it’s payed, but if you have a free developer key you can test it, which is probably enough for home usage)
http://developer.tomtom.com/io-docs
This site does not exist anymore.
Would you please share your php stuff?
I extracted the Script quickly from my OH setup.
Please fill in the waypoints and an API Key
https://pastebin.com/k6k87ZJw
Great.
Thanks for sharing!
