Depends on which version of the Pi you have. If it is a Pi2 or a Pi3 the answer is probably yes. If it is an original generation Pi, the answer is no because OH doesn’t run that well on the original Pi.
OH doesn’t really require that many resources (more RAM than anything else) and plays well with other servers, so long as everything is configured to listen on different ports.
