Hi All;
I seem to be facing an interesting situation here. I have openhab configured with readonly data from my EcoBee3 and SNMP gets from my router. The strange thing is that OpenHAB only runs for a few hours before it completely crashes. Sometimes the crash is so bad that it seems to take the system out with it to the point that I can no longer SSH into my RPi2.
As a new user I can’t upload any files so I will post some snippets of the latest hs_err file that got dumped by the crash:
# # A fatal error has been detected by the Java Runtime Environment: # # SIGSEGV (0xb) at pc=0x764ec06c, pid=1385, tid=1682343008 # # JRE version: Java(TM) SE Runtime Environment (8.0-b132) (build 1.8.0-b132) # Java VM: Java HotSpot(TM) Client VM (25.0-b70 mixed mode linux-arm ) # Problematic frame: # V [libjvm.so+0x16506c] CounterDecay::do_method(Method*)+0x4 # # Failed to write core dump. Core dumps have been disabled. To enable core dumping, try "ulimit -c unlimited" before starting Java again # # If you would like to submit a bug report, please visit: # http://bugreport.sun.com/bugreport/crash.jsp #
System Information:
OS:PRETTY_NAME="Raspbian GNU/Linux 8 (jessie)" NAME="Raspbian GNU/Linux" VERSION_ID="8" VERSION="8 (jessie)"
JVM Information:
pi@raspberrypi:/tmp $ java -version java version "1.8.0" Java(TM) SE Runtime Environment (build 1.8.0-b132) Java HotSpot(TM) Client VM (build 25.0-b70, mixed mode) pi@raspberrypi:/tmp $
OpenHab.log tail:
2016-01-17 23:43:35.943 [INFO ] [.service.AbstractActiveService] - Exec Refresh Service has been started 2016-01-17 23:43:39.899 [INFO ] [.service.AbstractActiveService] - SNMP Refresh Service has been started 2016-01-17 23:43:39.899 [INFO ] [.service.AbstractActiveService] - NTP Refresh Service has been started 2016-01-18 00:22:46.322 [WARN ] [g.openhab.io.net.http.HttpUtil] - Method failed: HTTP/1.1 500 Internal Server Error 2016-01-18 01:22:58.822 [WARN ] [g.openhab.io.net.http.HttpUtil] - Method failed: HTTP/1.1 500 Internal Server Error 2016-01-18 02:23:12.281 [WARN ] [g.openhab.io.net.http.HttpUtil] - Method failed: HTTP/1.1 500 Internal Server Error 2016-01-18 03:13:47.683 [WARN ] [inding.ntp.internal.NtpBinding] - couldn't establish network connection [host 'ptbtime1.ptb.de'] -> returning current sytem time instead 2016-01-18 03:23:25.706 [WARN ] [g.openhab.io.net.http.HttpUtil] - Method failed: HTTP/1.1 500 Internal Server Error 2016-01-18 04:23:39.729 [WARN ] [g.openhab.io.net.http.HttpUtil] - Method failed: HTTP/1.1 500 Internal Server Error 2016-01-18 05:23:53.165 [WARN ] [g.openhab.io.net.http.HttpUtil] - Method failed: HTTP/1.1 500 Internal Server Error 2016-01-18 05:58:54.845 [WARN ] [inding.ntp.internal.NtpBinding] - couldn't establish network connection [host 'ptbtime1.ptb.de'] -> returning current sytem time instead 2016-01-18 06:24:10.329 [WARN ] [g.openhab.io.net.http.HttpUtil] - Method failed: HTTP/1.1 500 Internal Server Error 2016-01-18 07:24:25.747 [WARN ] [g.openhab.io.net.http.HttpUtil] - Method failed: HTTP/1.1 500 Internal Server Error 2016-01-18 08:24:39.155 [WARN ] [g.openhab.io.net.http.HttpUtil] - Method failed: HTTP/1.1 500 Internal Server Error 2016-01-18 09:24:54.675 [WARN ] [g.openhab.io.net.http.HttpUtil] - Method failed: HTTP/1.1 500 Internal Server Error
