Which values do get printed out?
Looking at your sitemap only one digit hould be shonw on the text item. The visible chart by itself should show temp values only at the y-axis, the range of this axis is calculated based on the temperature range of the values. If the temperature range of all values is less then a degree, you will see decimal values there.
What happened is that your database gets values slowly, the chart for a week doesn’t get a new value every minute! Using the default setup only the chart for the last 8 houres would show and get the minute-wise data.
As posted before the chart axis are calculated to fit, themore values are stored the better the display.
