Strategies {
everyMinute : “0 * * * * ?”
Items {
// persist items on every change and every minute
Z1_actuator, Z2_actuator, Z1_Temp, Z2_Temp, Netatmo_Indoor_Temp, Netatmo_Outdoor_Temp : strategy = everyMinute, restoreOnStartup
To use in a sitemap chart Chartsonoff displaying the state of the actuator, but the persistence file is not created also when the Item change state:
2021-10-06 16:07:53.534 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘Z1_actuator’ changed from OFF to ON
2021-10-06 16:09:24.962 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘Z1_actuator’ changed from ON to OFF
Excuse me:
openHAB 3.2.0 Build #2446 on Raspberry PI4
I moved files from OH 2.5 via backup restore into a new installation
I have rrd4j installed and defined as default persistence, it’s already working well for other charts.
In /var/lib/openhab/persistence/rrd4j I see several rrd files for items I already have but no file for the new switch type I added in these days. All previous stored data are numbers:temperature. Only the new ones are switch that return a string ON/OFF
I never created files in this folder, should I create a new one? How?
I have to excuse myself!
Your item definition is correct (and not in the OH1 syntax, stupid .me).
I wo der if you rrd4j setup is still working. My guess is that the already editing .rrd files were created from the default ( rrd4j) setup ( which is working without instslling rrd4j and 2ithout setting it as default manually) . Creating an own setup did stop that one.
Do you see updates the old .rrd files?
I’d try to restart the rrd4j bundle ( no need the restart openHAB in toto).
Creating the .rrd files by hand is never needed!
I have already restarted it several times. Now I started debugging rrd4j and I saw this interesting message:
2021-10-07 08:18:56.702 [DEBUG] [d4j.internal.RRD4jPersistenceService] - Did not create rrd4j database for item ‘Z1_actuator’ since no rrd definition could be determined. This is likely due to an unsupported item type.
2021-10-07 08:18:56.705 [DEBUG] [d4j.internal.RRD4jPersistenceService] - Could not find item ‘Z1_actuator’ in rrd4j database
It looks as switches are no more supported, also if they are still listed
NOTE: rrd4j is for storing numerical data only. It cannot store complex data types. The supported item types are therefore only Switch (internally mapped to 0/1), Dimmer, Number, Contact (internally mapped to 0/1), Rollershutter and Color (only brightness component stored).
Me stupid! Copied the wrong line. It was the first switch I needed to store in rrd4j, so I did not notice that I took the line where I read the status of that actuator, because I do not need to control it, but only to know if it’s open or close.
Now I defined a new line and the persistence file is created!
Please excuse me for my error.
