I am running OpenHab2 on a RPI with onewire counters connected to electricity meters and temperature sensors. I can read the values of the counter and temperature sensors in OpenHab BasicUI as single values. I also can plot the temperature values in graphs using HabPanel. But I can not plot the counters the way that I want to.
My onewire items:
Number Temp_Panna1 "Panna1 Temp [%.1f °C]" <temperature> (Temp_Group) { onewire="deviceId=28.589D70020000;propertyName=temperature;refreshinterval=10" }
Number Temp_Panna2 "Panna2 Temp [%.1f °C]" <temperature> (Temp_Group) { onewire="deviceId=28.865870020000;propertyName=temperature;refreshinterval=10" }
Number Temp_Panna3 "Panna3 Temp [%.1f °C]" <temperature> (Temp_Group) { onewire="deviceId=28.65E02F040000;propertyName=temperature;refreshinterval=10" }
Number Temp_Panna4 "Panna4 Temp [%.1f °C]" <temperature> (Temp_Group) { onewire="deviceId=28.ABB52F040000;propertyName=temperature;refreshinterval=10" }
Number Count_1A "Counter1A [%d st]" { onewire="deviceId=1D.89060F000000;propertyName=counters.A;refreshinterval=10" }
Number Count_1B "Counter1B [%d st]" { onewire="deviceId=1D.89060F000000;propertyName=counters.B;refreshinterval=10" }
Number Count_2A "Counter2A [%d st]" { onewire="deviceId=1D.F7F60E000000;propertyName=counters.A;refreshinterval=10" }
Number Count_2B "Counter2B [%d st]" { onewire="deviceId=1D.F7F60E000000;propertyName=counters.B;refreshinterval=10" }
Group Temp_Group
My rrd4j.persist:
Strategies {
everyMinute:"0 * * * * ?"
everyHour : "0 0 * * * ?"
everyDay : "0 0 0 * * ?"
// if no strategy is specified for an item entry below, the default list will be used
default = everyChange
Items {
Temp_Group* : strategy = everyMinute
* : strategy = everyChange, restoreOnStartup
My problem is that I need to plot the counter values as COUNTER datasource type but this seems not to work. The counter value is very large and when the counter increase just a few Wh this change can not be read out with the current scale/resolution.
I have tried to use the COUNTER datasource by inserting the following to openhab.cfg or rrd4j.cfg but when I reboot the RPI all the changes in the cfg-files are vanished.
rrd4j:raknare.def=COUNTER,900,0,U,300
rrd4j:raknare.archives=AVERAGE,0.5,1,365:AVERAGE,0.5,7,300
rrd4j:raknare.items=Count_1A,Count_1B,Count_2A,Count_2B
When I reboot the RPI I also loss all temperature and counter historical data in the HABPANEL rrd4j graphs.
-Why can I not plot the onewire counters as COUNTER datasource?
-Why do all historical data dissappear at reeboot?
