Hi!
I have several errors on RRD4j persistence service stating that the item value must be between 0 and 100. Item must be somekind of a dimmer or a group with base type of dimmers. But the error message does not gives any hint on which item is the cause of the problem (I have >700 items). I’ve tried to set persistence service to DEBUG but the error message did not changed. Sorrounding log lines has no relation to the error as I checked several of them but they are not dimmer at all.
2021-12-06 15:46:01.397 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'QueryablePersistenceService.query()' on 'org.openhab.persistence.rrd4j.internal.RRD4jPersistenceService@cd5aea6': Value must be between 0 and 100
java.lang.IllegalArgumentException: Value must be between 0 and 100
at org.openhab.core.library.types.PercentType.validateValue(PercentType.java:93) ~[bundleFile:?]
at org.openhab.core.library.types.PercentType.<init>(PercentType.java:52) ~[bundleFile:?]
at org.openhab.persistence.rrd4j.internal.RRD4jPersistenceService.mapToState(RRD4jPersistenceService.java:415) ~[?:?]
at org.openhab.persistence.rrd4j.internal.RRD4jPersistenceService.query(RRD4jPersistenceService.java:272) ~[?:?]
at jdk.internal.reflect.GeneratedMethodAccessor56.invoke(Unknown Source) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
at org.openhab.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:154) [bundleFile:?]
at org.openhab.core.internal.common.Invocation.call(Invocation.java:52) [bundleFile:?]
2021-12-06 15:46:01.401 [ERROR] [ence.internal.PersistenceManagerImpl] - Exception occurred while querying persistence service 'rrd4j': Value must be between 0 and 100
Is it possible to determine which of the items causing this? (I have four messages of these at startup recently) Or is it possible to have the error message to be customized (feature request?) to give back the originating item?
I’m on currently 3.2.M5 running in a docker container.
Thank you.
