i was having a working installation of OH 2.5.12 on an RPi. Now I ran a backup with the backup tool of Openhabian-Config and copied the resulting file to a new system.
The new server is a debian LXC container where i had installed Debian 10 and Openhabian manually and restored the Backup from the aforementioned RPi. After completion everything worked fine, except the Graphs for RRDJ. All Graphs in the Sitemap showing questionmarks only.
Now I have checked that the rrdj files are being generated in the correct directory.
When I run http://192.168.1.40:8080/rrdchart.png?items=TemperaturWoZi&period=h this resulted in the following output:
HTTP ERROR 500
Problem accessing /rrdchart.png. Reason:
Server Error
Caused by:
java.lang.ExceptionInInitializerError
at org.rrd4j.graph.RrdGraphDef.(RrdGraphDef.java:80)
at org.openhab.persistence.rrd4j.internal.charts.RRD4jChartServlet.createChart(RRD4jChartServlet.java:261)
at org.openhab.persistence.rrd4j.internal.charts.RRD4jChartServlet.service(RRD4jChartServlet.java:161)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:852)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:544)
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:536)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1581)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1307)
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:293)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:482)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1549)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1204)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80)
at org.eclipse.jetty.server.Server.handle(Server.java:494)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:374)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:268)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103)
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:336)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:313)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:171)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:129)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:367)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:782)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:918)
at java.base/java.lang.Thread.run(Unknown Source)
Caused by: java.lang.RuntimeException: java.io.IOException: Problem reading font data.
at org.rrd4j.graph.RrdGraphConstants$FontConstructor.getFont(RrdGraphConstants.java:287)
at org.rrd4j.graph.RrdGraphConstants.(RrdGraphConstants.java:304)
… 36 more
Caused by: java.io.IOException: Problem reading font data.
at java.desktop/java.awt.Font.createFont0(Unknown Source)
at java.desktop/java.awt.Font.createFont(Unknown Source)
at org.rrd4j.graph.RrdGraphConstants$FontConstructor.getFont(RrdGraphConstants.java:283)
… 37 more
Caused by:
… 37 more
Caused by:
I have re-run the system setting for the rights. I have removed and reinstalled the RRDJ Persistence service. Nothing changed anything.
Any ideas what went wrong here ? I am not a Linux guy so I am kind of stuck.
Any help would be appreciated.
Thanks a lot
Frank
