For some strange reason DP TimeOfDay is doing this
2019-09-24 18:55:00.004 [INFO ] [e.smarthome.model.script.Time Of Day] - Calculating time of day...
2019-09-24 18:55:00.012 [INFO ] [e.smarthome.model.script.Time Of Day] - Calculating time of day...
2019-09-24 18:55:00.015 [INFO ] [e.smarthome.model.script.Time Of Day] - Calculated time of day is EVENING
2019-09-24 18:55:00.017 [INFO ] [e.smarthome.model.script.Time Of Day] - Calculated time of day is EVENING
18:55 equals to Sunset
which is being triggered by
Channel 'astro:sun:local:set#event' triggered START or
But why it’s running twice is bit of mystery. It’s doing it everyday at Sunset. And on evening trigger (which is sunset -90min)
Is astrobinding boardcasting sunset twice or something?
similar story is with Day
2019-09-23 06:50:00.005 [INFO ] [e.smarthome.model.script.Time Of Day] - Calculating time of day...
2019-09-23 06:50:00.018 [INFO ] [e.smarthome.model.script.Time Of Day] - Calculated time of day is DAY
2019-09-23 10:29:37.890 [INFO ] [e.smarthome.model.script.Time Of Day] - Calculating time of day...
2019-09-23 10:29:41.738 [INFO ] [e.smarthome.model.script.Time Of Day] - Calculated time of day is DAY
2019-09-23 10:29:49.401 [INFO ] [e.smarthome.model.script.Time Of Day] - Calculating time of day...
2019-09-23 10:29:49.406 [INFO ] [e.smarthome.model.script.Time Of Day] - Calculated time of day is DAY
2019-09-23 10:30:52.969 [INFO ] [e.smarthome.model.script.Time Of Day] - Calculating time of day...
2019-09-23 10:30:52.975 [INFO ] [e.smarthome.model.script.Time Of Day] - Calculated time of day is DAY
2019-09-23 10:31:01.300 [INFO ] [e.smarthome.model.script.Time Of Day] - Calculating time of day...
2019-09-23 10:31:04.312 [INFO ] [e.smarthome.model.script.Time Of Day] - Calculated time of day is DAY
2019-09-23 10:48:41.728 [INFO ] [e.smarthome.model.script.Time Of Day] - Calculating time of day...
2019-09-23 10:48:41.736 [INFO ] [e.smarthome.model.script.Time Of Day] - Calculated time of day is DAY
2019-09-23 14:48:27.153 [INFO ] [e.smarthome.model.script.Time Of Day] - Calculating time of day...
2019-09-23 14:48:29.996 [INFO ] [e.smarthome.model.script.Time Of Day] - Calculated time of day is DAY
but triggers are not calling it at these hours
System started or // run at system start in case the time changed when OH was offline
Channel 'astro:sun:local:rise#event' triggered START or
Channel 'astro:sun:minus90:set#event' triggered START or
Time cron "0 1 0 * * ? *" or // one minute after midnight so give Astro time to calculate the new day's times
Time cron "0 0 6 * * ? *" or
Time cron "0 0 23 * * ? *"
You should see the events from Astro in events.log. Look there to see if it’s generating two events at that time.
Is the .rules file being reloaded at those times? Any time the file reloads (e.g. you made a change and saved it) the Rule will trigger (System started).
so minus90 is triggered at same time, well … crap
(@rlkoshak btw if astro is triggered at same time local and minu90 it means TimeOfDay is never at state AFTERNOON …)
this behaviour explains EVENING but does not explain DAY
If they are occurring at the same time there is something wrong with the minus90. There is an offset defined on the minus90 causing that event to trigger 90 minutes before the actual set.
It may not look wrong, but the offsets are not being used so there is something wrong. I don’t use .things files so I’ve no recommendations for a fix. Either your minus90 Thing is triggering at actual sunset or your home Thing is triggering 90 minutes before sunset, causing them both to occur at the same time.
All I can suggest is that the file was changing somehow to cause OH to reload it (you would see reloads in openhab.log) or some other event was occurring at those times to cause the Rule to trigger. Look in events.log at those times to see if there is a correlation.
The Astro binding will automatically put a Thing in the Inbox based on your configured Lat/Long. Did you by chance accidentally accept that Thing? That could cause a duplicate.
btw @rlkoshak have you set offset for start/end or for event only or all three of them? I had it as whole event with start/stop at 0, wondering if that might be an issue.
My thinking was if I set offset for whole event, start/end will shift as well, or … maybe not?
I only apply the offset to the START Channel. I only use the START event so I don’t know if it also moves the END event too. The Rule triggers on the START event. I don’t use the Range Event Channel.
works on range event shift, but somehow start was not affected
If you change it to this:
Channel 'astro:sun:m90:set#start' triggered START
it does not matter if you shift range event, but shift start is enough
dunno if that’s expected or not, but it seems it does matters if you are shifting start or whole event and which trigger you actually use as it seems set#start START may differ from set#event START if shift is used
