I have rule that monitor a switch, but it takes 8 seconds for the rule to catch that change
2019-05-10 23:38:49.510 [vent.ItemStateChangedEvent] - LS_Front changed from OFF to ON
2019-05-10 23:38:57.643 [INFO ] [se.smarthome.model.script.home.rules] - LS_Front Rule runs
Can I make this quicker ?
I have single rule fule with 510 lines in it
Just to be sure, does it take about 8s everytime, or just the first time after the rule is changed/loaded?
A large rule file takes some time to compile.
Nope. The moment I press I see it in the logs.
2019-05-11 01:05:26.685 [ome.event.ItemCommandEvent] - Item âLS_FrontOutsideâ received command OFF
2019-05-11 01:05:26.702 [nt.ItemStatePredictedEvent] - LS_FrontOutside predicted to become OFF
2019-05-11 01:05:26.721 [vent.ItemStateChangedEvent] - LS_FrontOutside changed from ON to OFF
2019-05-11 01:05:26.790 [vent.ItemStateChangedEvent] - mqtt_topic_7489427a_frontlight changed from ON to OFF
I also have rules that monitor ZWAVE devices for double/triple press and the work instantly.
var Timer tMotion = null
var Timer tMotionLight = null
var Number nMotion
rule "BI Motion FC"
Item BI_FC_Motion changed from OFF to ON
logInfo("home.rules", "Motion rule runs")
if(tMotion === null) {
tMotion=createTimer(now.plusMillis(2500), [|
if(nMotion == 0) sendTelegramPhoto("sec", "http://192.168.192.104:81/", "Front Cam movement")
else sendTelegramPhoto("sec", "http://192.168.192.104:81/", "")
nMotion+=1
switch (nMotion) {
case 1: tMotion.reschedule(now.plusSeconds(1))
case 2: tMotion.reschedule(now.plusSeconds(1))
case 3: tMotion.reschedule(now.plusSeconds(2))
default: tMotion=null
nMotion = 0
if(tMotionLight === null && sun == false && LS_FrontOutside.state == OFF) {
tMotionLight = createTimer(now.plusMinutes(5), [|
LS_FrontOutside.sendCommand(OFF)
tMotionLight = null
LS_FrontOutside.sendCommand(ON)
logInfo("home.rules", "Lights on for Camera")
Should be very similar, but more save in question of multiple triggers. The createTimers are out of execution order, as the if() statement should be locked immediately.
Iâm not familiar with switch+case until now, but it seems like it only check nMotion once and therefore will send only 1 telegram photo. isnât it ? I donât see it behave like while loop
Should have said something more in question of code
// global vars defined on top of rules file
var Timer tMotion = null //timer for delayed pictures
var Timer tMotionLight = null //timer for light
var Number nMotion //counter for pictures
rule "BI Motion FC"
if(tMotion === null) { //only if no timer is started yet
tMotion=createTimer(now.plusMillis(2500), [| //execute code after 2.5 seconds
if(nMotion == 0) sendTelegramPhoto("sec", "http://192.168.192.104:81/", "Front Cam movement") //on first step
else sendTelegramPhoto("sec", "http://192.168.192.104:81/", "") //every other step
nMotion+=1 //always add 1 to nMotion
switch (nMotion) {
case 1: tMotion.reschedule(now.plusSeconds(1)) //first step
case 2: tMotion.reschedule(now.plusSeconds(1)) //second step
case 3: tMotion.reschedule(now.plusSeconds(2)) //third step
default: tMotion=null //fourth step: deinitialize timer
nMotion = 0 //not delayed! set step to 0
if(tMotionLight === null && sun == false && LS_FrontOutside.state == OFF) { //not delayed! test light
tMotionLight = createTimer(now.plusMinutes(5), [| //execute code after 5 minutes
tMotionLight = null
LS_FrontOutside.sendCommand(ON) //not delayed!
Timers are only created if they donât exist yet. even if a rule is triggered twice, as the timer is created immediately, this part is âlockedâ.
Light is only switched on once, and also switched off once.
There will be 4 photos, after 2.5, 3.5, 4.5 and 6.5 seconds. First photo has a headline.
