Hi, i updated from an very early version of openHab2 to the current version. I currently have a mixed setup of V1 and V2 plugins because i am not able to migrate all my config currently.
Now i have an issue with the my rules with cron trigger.
I used the NTP plugin to get the current date and time. This is completely configured in V2 plugin of NTP:
Thing:
ntp:ntp:demo [ hostname=“nl.pool.ntp.org”, refreshInterval=60, refreshNtp=30, timeZone=“Europe/Berlin”, locale=“de” ]
Item:
DateTime Date2 “Date2 [%1$tA, %1$td.%1$tm.%1$tY %1$tH:%1$tM]” (gEG) { channel=“ntp:ntp:demo:dateTime”, knx=“11.001:0/1/0, 10.001:0/1/1” }
sitemap:
Text item=Date2
The KNX - Bus show the correct date and time and also in the PaperUI -> Control overview the date is correct. But in my sitemap where the value will be shown is the wrong value. There is a shift by 1h.
PaperUi - Control: 16:00
GUI: 15:00
And the GUI time will also be used in the rule for the cron timer.
If i change it to the wrong timezone, the time of the KNX devices will be wrong. Does someone have an idea what will be the problem?
Thank you for your help.
bb
