Rule does not fire anymore
Hi guys,
i have a Problem with a rule.
It doesn´t fire anymore, and a don´t know why.
It´s quite smiple, but i am not able to get it work.
Here is my Rule:
rule "Alle Rollo rauf"
	Item Rollo_gesamt changed to 0
		Rollo_11.sendCommand(UP)
		Thread::sleep(2000)
		Rollo_12.sendCommand(UP)
		Thread::sleep(2000)
		Rollo_1.sendCommand(UP)
		Thread::sleep(2000)
		Rollo_2.sendCommand(UP)
		Thread::sleep(2000)
		Rollo_3.sendCommand(UP)
		Thread::sleep(2000)
		Rollo_4.sendCommand(UP)
		Thread::sleep(2000)
		Rollo_5.sendCommand(UP)
		Thread::sleep(2000)
		Rollo_6.sendCommand(UP)
		Thread::sleep(2000)
		Rollo_7.sendCommand(UP)
		Thread::sleep(2000)
		Rollo_8.sendCommand(UP)
		Thread::sleep(2000)
		Rollo_9.sendCommand(UP)
		Thread::sleep(2000)
		Rollo_10.sendCommand(UP)
		Rollo_Dummy_1.sendCommand(OFF)							  Rollo_Dummy_2.sendCommand(OFF)
		Rollo_Dummy_3.sendCommand(OFF)
		Rollo_Dummy_4.sendCommand(OFF)
		Rollo_Dummy_5.sendCommand(OFF)
		Rollo_Dummy_6.sendCommand(OFF)
		Rollo_Dummy_7.sendCommand(OFF)
		Rollo_Dummy_8.sendCommand(OFF)
		Rollo_Dummy_9.sendCommand(OFF)
		Rollo_Dummy_10.sendCommand(OFF)
		Rollo_Dummy_11.sendCommand(OFF)
		Rollo_Dummy_12.sendCommand(OFF)
		Szene_7_PM_SZ.sendCommand(7)
		Szene_9_PM_Noel.sendCommand(9)
		Szene_11_PM_Lia.sendCommand(11)
My Item changed to 0 but nothing happens:
2018-09-21 08:23:41.627 [ome.event.ItemCommandEvent] - Item 'Rollo_gesamt' received command 0
What could that be?
I am running on OH 2.3
The opposite rule works great:
rule "Alle Rollo runter"
	Item Rollo_gesamt changed to 100
		sendCommand(Rollo_11,DOWN)
		Thread::sleep(2000)
		sendCommand(Rollo_12,DOWN)
		Thread::sleep(2000)
		sendCommand(Rollo_1,DOWN)
		Thread::sleep(2000)
		sendCommand(Rollo_2,DOWN)
		Thread::sleep(2000)
		sendCommand(Rollo_3,DOWN)
		Thread::sleep(2000)
		sendCommand(Rollo_4,DOWN)
		Thread::sleep(2000)
		sendCommand(Rollo_5,DOWN)
		Thread::sleep(2000)
		sendCommand(Rollo_6,DOWN)
		Thread::sleep(2000)
		sendCommand(Rollo_7,DOWN)
		Thread::sleep(2000)
		sendCommand(Rollo_8,DOWN)
		Thread::sleep(2000)
		sendCommand(Rollo_9,DOWN)
		Thread::sleep(2000)
		sendCommand(Rollo_10,DOWN)
best regards
Vaillan
I restart the Service, but it also didn`t work.
After i set the Rollo_gesamt Value to 100, the rule fires now, if i set the vaule to 0.
It seems that the Item Status value was broken.
But i thought that a Service restart should reset all values also. :thinking:
It is working now.
But nevertheless i should rework my rules.
Thanks for help
vaillan
Please keep in mind, that there is a difference between the triggers
changed and received command
changed will trigger if the state of the item is changing, or, when using changed to 0, it will trigger when the state changed from a state other than 0 to 0
received command will trigger, if the item received a command, regardless, if the state is changed or not. received command will also include the commands UP/DOWN/STOP for a rollershutter item, while the state will never change to one of those commands.
