the following rules show me the last 7 incoming and outgoing calls. The process works so far, but has a blemish. The “Gesprächsdauer messen” rule returns the duration for all phone calls. However, if a call is being made, another (incoming) phone call destroys the measurement - although the remote station hears a busy signal.
I’ve been looking for a solution for a while now. Before activating the “Gesprächsdauer messen” rule, a check should be carried out to determine whether a call is currently being made. The rule can only be executed if this is not the case.
Unfortunately, I have no idea how the process can be carried out successfully. Can someone help me?
Thanks in advance.
var Long lPhoneStart = 0
var Integer iSeconds = 0
var strFax = "030123456789" // Fax-Nummern
rule "Gesprächsdauer messen"
Item fritzCallRinging changed
val strNew = newState.toString
val strPrev = previousState.toString
if(strNew == "ACTIVE") {
if(strPrev == "RINGING")
logInfo("call", "Eingehender Anruf: Verbindung hergestellt")
else if(strPrev == "DIALING")
logInfo("call", "Ausgehender Anruf: Verbindung hergestellt")
lPhoneStart = now.toInstant.toEpochMilli
} else if(strPrev == "ACTIVE" && strNew == "IDLE") {
logInfo("call", "Aktiver Anruf: Verbindung beendet")
iSeconds = ((now.toInstant.toEpochMilli - lPhoneStart)/1000).intValue
var strTime = ""
if(iSeconds !== null)
strTime = transform("JS","secinhms.js",iSeconds.toString)
logInfo("call", "Beendigung des {}gangsgespräches nach {}",if(Flag_1_ADauer.state.toString=="...")"Aus" else "Ein",strTime)
if(Flag_1_EDauer.state == "...")
Flag_1_EDauer.postUpdate(strTime)
else if(Flag_1_ADauer.state == "...")
Flag_1_ADauer.postUpdate(strTime)
rule "Eingehender Anruf"
Item fritzCallRinging changed to RINGING
Thread.sleep(500) // Wert eventuell auch noch erhöhen
if(!(fritzIncomingCall.state instanceof StringListType)) return;
val incCall = fritzIncomingCall.state as StringListType
gEFlags.members.sortBy[ name ].reverseView.forEach[ i |
val num = Integer::parseInt(i.name.split("_").get(1))
val art = i.name.split("_").get(2)
if(num > 1) {
val myItem = gEFlags.members.filter[ j | j.name.split("_").get(1) == (num-1).toString && j.name.endsWith(art)].head
i.postUpdate(myItem.state)
// val incCall = fritzIncomingCall.state as StringListType
// val ourNumber = incCall.getValue(0)
val callerNumber = incCall.getValue(1)
val tr064Actions = getActions("tr064","tr064:fritzbox:1")
var callerName = tr064Actions.phonebookLookup(callerNumber)
if(strFax.contains(callerNumber.toString))
callerName = "Faxgerät"
if(callerName==callerNumber)
callerName = "unbekannt"
val callDate = String.format("%1$td.%1$tm.%1$tY", now)
val callTime = String.format("%1$tH:%1$tM", now)
Flag_1_EName.postUpdate(callerName)
Flag_1_ETel.postUpdate(callerNumber)
Flag_1_EDat.postUpdate(callDate)
Flag_1_ETime.postUpdate(callTime)
Flag_1_EDauer.postUpdate("...") // signalisiert, dass gerade telefoniert wird
logInfo("call", "Eingang {} | {} | {} | {}",callerName,callerNumber,callDate,callTime)
rule "Ausgehender Anruf"
Item fritzCallRinging changed to DIALING
if(!(fritzOutgoingCall.state instanceof StringListType)) return;
val outCall = fritzOutgoingCall.state as StringListType
gAFlags.members.sortBy[ name ].reverseView.forEach[ i |
//logInfo("call","Move - zu Item {} Nummer ist {} Name endet mit {}",i.name,num,art)
if(num > 1) {
val myItem = gAFlags.members.filter[ j | j.name.split("_").get(1) == (num-1).toString && j.name.endsWith(art)].head
//val outCall = fritzOutgoingCall.state as StringListType
var String calledNumber = outCall.getValue(0)
// var String ourNumber = outCall.getValue(1)
var calledName = tr064Actions.phonebookLookup(calledNumber)
if(strFax.contains(calledNumber.toString))
calledName = "Faxgerät"
if(calledName==calledNumber)
calledName = "unbekannt"
Flag_1_AName.postUpdate(calledName)
Flag_1_ATel.postUpdate(calledNumber)
Flag_1_ADat.postUpdate(callDate)
Flag_1_ATime.postUpdate(callTime)
Flag_1_ADauer.postUpdate("...") // signalisiert, dass gerade telefoniert wird
logInfo("call", "Ausgang {} | {} | {} | {}",calledName,calledNumber,callDate,callTime)
rule "Anruf abgebrochen"
Item fritzCallRinging changed from DIALING to IDLE
logInfo("FRITZ!Box", "Anruf: Teilnehmer nicht erreichbar")
Flag_1_ADauer.postUpdate("abgebr.")
I did not understand all the code but to achieve what you want to do I would create an item “ongoing_call” and if a call is coming in or out → ongoing_call.sendCommand(ON).
Before Gesprächsdauer messen is excuted you can test
You mean create a dummy item? I’ve already tried something like this. However, this item must also be switched from ON to OFF. Then, however, the processing of the rules is crucial. So far I haven’t found a solution this way. Or am I going the wrong way?
I have now made many attempts to find a solution with your suggestion. Unfortunately without success, I need another way. With this method I only produced errors. Thanks anyway, maybe I can get some other tips.
rule "Gesprächsdauer messen ON"
Item ongoing_call changed to ON
else if(strPrev == "DIALING") {
rule "Gesprächsdauer messen OFF"
Item ongoing_call changed to OFF
var strTime = ""
if(num > 1) {
if(num > 1) {
ongoing_call.sendCommand(OFF)
Minor corrections had to be made, but in this constellation no result is transferred to the item Flag_1_ADauer for the duration of a telephone call.
Item Flag_Messen changed to ON
} else if(strPrev == "DIALING") {
Item Flag_Messen changed to OFF
var strTime = ""
Flag_Messen.sendCommand(ON)
if(num > 1) {
if(num > 1) {
Flag_Messen.sendCommand(OFF)
Flag_Messen is a dummy item (switch ON/OFF) and should only provide a status. It has the same function as the ongoing_call element you mentioned.
For each phone call (outgoing and incoming) I have provided 5 items: name, number, date, time and duration. The item Flag_1_ADauer adopts the value from the variable strTime after the end of an outgoing call and a correct execution of the rule “Gesprächsdauer messen”.
Unfortunately, this value is not passed in your example.
I can’t see what types your items are but I would decide for one. I would choose “number” and stop to update it with “…”. Thats a string and does no good. Make an ongoing call 555555555 or whatever you like. Not …
ADauer is of the type String And “…” is only intended to indicate that a call is in progress. The variable ‘lPhoneStar’ is declared globally with ‘var Long lPhoneStart = 0’ at the beginning of the code.
