I’m playing around with my small z-wave setup and can’t get my first test rule to work. For hardware I use Aeotec z-stick gen5 and a aeotec multisensor 6. The simple rule I’m trying to achieve is to get openHab to send me a mail when motion is detected. When the sensor changes from closed to open the mail never gets sent.
What am I doing wrong and how can I troublshoot to see if a rule has been triggerd?
rule "notify"
Item Motion_Sensor1 changed from CLOSED to OPEN
sendMail(“xxx@yyy.zzz”, “Motion detected!”, “OpenHAB has detected motion.”)
Suggestion:
Create a imaginary item in the items file:
Number Help "Help [%s]"
Create a text in sitemaps:
Text "Help"
In rules send command instead of mail:
sendCommand(Help, “Works!”)
If you see “Works” in you UI then the rule works and problem is with the sendMail.
In later case you have to check here.
Cheers
Björn
exactly. break apart your issue into its core bindings.
since you have zwave and mail going on, make sure the zwave sensor triggers, and that the mail works. do like Bjorn suggests above and test the zwave working by sending the help. if that works its the mail. if it doesnt work, its either your rule, or your zwave. can you see the status of the multisensor on your sitemap, or do you just know its triggered from the LED?
Thanks, I added the following line in my default.items -file:
Number Help “Help [%s]” (gG1)
And edited the default.rules with this:
import org.openhab.core.library.types.*
import org.openhab.core.persistence.*
import org.openhab.model.script.actions.*
rule “notify”
sendCommand(Help, “Motion detected”)
sendMail(“xxx@yyy.zzz”, “Motion detected!”, “OpenHAB has detected motion”)
rule "notify2"
Item Motion_Sensor1 changed from OPEN to CLOSED
sendCommand(Help, "Motion gone...")
When looking at the group gG1 with the sesor not detecting motion I get the following output:
When the sesor detects motion this is what openHab outputs:
The green LED on the sensor does light up when it detects motion.
Is there an easy way to verify that sending mail works?
rule "notify"
Item Motion_Sensor1 received update
rule "startup"
System started
sendMail(“xxx@yyy.zzz”, “System started”, “OpenHAB has started”)
rule "shutdown"
System shuts down
sendMail(“xxx@yyy.zzz”, “System shutting down”, “OpenHAB has started shut down”)
In my book that should trigger whenever the motion sensor is changed to closed or open and the other rules to trigger when openhab start up and shuts down. Still no mails What am I missing? Do I have the correct includes? I just copied them from the demo-file.
(and how do I format the code nicely in the forum instead of plain text? )
Before shuting down my lab to go to bed I noticed this in the command window:
2016-02-15 21:38:15.267 [ERROR] [o.o.c.s.ScriptExecutionThread ] - Error during the execution of rule ‘notify’: The name ‘sendMail(,,)’ cannot be resolved to an item or type.
rule "notify"
You see then in your text item the text “Motion detected”.
If you see only “-” then maybe something is not working in your item definition “Motion_Sensor1” or somewhere else.
Pls advise what addons you have implemented?
If this part works replace
"sendCommand(Help, “Motion detected”)" with
"sendMail(“xxx@yyy.zzz”, “Motion detected!”, “OpenHAB has detected motion”)".
If you then see the error[quote=“z-wave, post:6, topic:7501”]
Before shuting down my lab to go to bed I noticed this in the command window:2016-02-15 21:38:15.267 [ERROR] [o.o.c.s.ScriptExecutionThread ] - Error during the execution of rule ‘notify’: The name ‘sendMail(,)’ cannot be resolved to an item or type.
[/quote]
write again.
Cheers
Björn
