Search thoroughly, also through examples but somehow I can’t figure out why this rule doesn’t work.
Rules:
var logger = Java.type("org.slf4j.LoggerFactory").getLogger("org.openhab.model.script.Rules.DoorsAndWindows");
var ScriptExecution = Java.type("org.openhab.core.model.script.actions.ScriptExecution");
var ZonedDateTime = Java.type("java.time.ZonedDateTime");
scriptExtension.importPreset("default");
this.OPENHAB_CONF = (this.OPENHAB_CONF === undefined) ? java.lang.System.getProperty("openhab.conf") : this.OPENHAB_CONF;
load(OPENHAB_CONF + "/automation/lib/javascript/personal/utils.js")
var doorsOpen = getNames("gDeurenBg", function(i) { return i.state == OPEN; });
var msg = ""; var prio = "2";
var trgrItem = event.itemName;
if(trgrItem == "gDeurenBg") {
var msgHeader = "Deur/raam geopend terwijl er niemand thuis is! Open deuren/ramen: "
} else {
var msgHeader = "Er is niemand thuis en de volgende deuren/ramen staan nog open: "
msg = msgHeader + doorsOpen;
var sendMsg = function(msg, prio){
if(ir.getItem("mainPresence").state == "OFF"){
logger.info("60 seconden voorbij. Verstuur bericht");
sendPushover(msg, prio);
} else if(ir.getItem("mainPresence").state == "ON"){
logger.info("60 seconden voorbij maar mainPresence is ON.")
logger.info("Deur/raam geopend. Timer gestart");
logger.info("ZDT now + 1 min is " + ZonedDateTime.now().plusMinutes(1));
var msgTimer = ScriptExecution.createTimer(ZonedDateTime.now().plusMinutes(1), sendMsg(msg, prio));
Log:
2022-04-27 23:31:24.905 [INFO ] [b.model.script.Rules.DoorsAndWindows] - Deur/raam geopend. Timer gestart
2022-04-27 23:31:24.911 [INFO ] [b.model.script.Rules.DoorsAndWindows] - ZDT now + 1 min is 2022-04-27T23:32:24.906714+02:00[Europe/Amsterdam]
2022-04-27 23:31:24.933 [INFO ] [b.model.script.Rules.DoorsAndWindows] - 60 seconden voorbij. Verstuur bericht
2022-04-27 23:31:24.939 [INFO ] [b.model.script.Rules.DoorsAndWindows] - Pushover message with priority 2 sent: "Deur/raam geopend terwijl er niemand thuis is! Open deuren/ramen: middelste achterdeur"
2022-04-27 23:31:25.283 [ERROR] [e.automation.internal.RuleEngineImpl] - Failed to execute rule 'DoorOpenAway': Fail to execute action: 5
It did work prior to inserting my timer and the sendMsg-function. I reviewed multiple examples for the timers in Javascript (rule is not ECMA-2021 based) but could not find a solution. Maybe I am mixing things up…
Any help appreciated!.
