No nothing special , the Rules Engines are active …
openhab> bundle:list |grep Rule
161 │ Active │ 80 │ 3.1.0 │ openHAB Core :: Bundles :: Automation Script RuleSupport
198 │ Active │ 80 │ 3.1.0 │ openHAB Core :: Bundles :: Model Rules
199 │ Active │ 80 │ 3.1.0 │ openHAB Core :: Bundles :: Model Rule IDE
200 │ Active │ 80 │ 3.1.0 │ openHAB Core :: Bundles :: Model Rules Runtime
a curios thing is that the logs shows afterwards direct a exception:
18:41:42.955 [DEBUG] [re.automation.internal.RuleEngineImpl] - Rule engine not yet started - not executing rule ‘58961ea251’,
18:41:42.956 [DEBUG] [t.core.internal.GsonMessageBodyWriter] - Failed writing HTTP response, since other side closed the connection
18:41:42.957 [DEBUG] [g.openhab.core.io.rest.SseBroadcaster] - Sending event to sink failed
org.eclipse.jetty.io.EofException: Closed
at org.eclipse.jetty.server.HttpOutput.checkWritable(HttpOutput.java:768) ~[bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:792) ~[bundleFile:9.4.40.v20210413]
at java.io.OutputStream.write(OutputStream.java:122) ~[?:?]
at org.apache.cxf.jaxrs.sse.OutboundSseEventBodyWriter.writeTo(OutboundSseEventBodyWriter.java:113) ~[bundleFile:3.4.3]
at org.apache.cxf.jaxrs.sse.OutboundSseEventBodyWriter.writeTo(OutboundSseEventBodyWriter.java:40) ~[bundleFile:3.4.3]
at org.apache.cxf.jaxrs.sse.SseEventSinkImpl.dequeue(SseEventSinkImpl.java:238) ~[bundleFile:3.4.3]
at org.eclipse.jetty.server.handler.ContextHandler.handle(ContextHandler.java:1520) [bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.server.AsyncContextState$1.run(AsyncContextState.java:153) [bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:882) [bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1036) [bundleFile:9.4.40.v20210413]
18:41:42.960 [DEBUG] [g.openhab.core.io.rest.SseBroadcaster] - Closing SSE event sink
org.eclipse.jetty.io.EofException: null
yes the rules runs also if I run this manually. I checked the source code of the RulesEngineImpl Class and as I understood this has something todo with the startlevel but I can’t identify how I can set the startlevel of the rule.
protected void runRule(String ruleUID, TriggerHandlerCallbackImpl.TriggerData td) {
if (thCallbacks.get(ruleUID) == null) {
// the rule was unregistered
return;
if (!started) {
logger.debug("Rule engine not yet started - not executing rule '{}',", ruleUID);
return;
started will be set to true here but I can’t find out how I have to configure the trigger:
maybe the current state is NULL or already ON?
go to MainUI’s Developer Tools and start API Explorer.
choose items - post and send OFF and then ON to your item.
or even better change your rule to received command ON
I tried using the API explorer and sending ON and OFF with the following result in the logfile but unfortunately without sending an email.
21:48:05.281 [DEBUG] [re.automation.internal.RuleEngineImpl] - The trigger ‘1’ of rule ‘58961ea251’ is triggered.
21:48:05.281 [DEBUG] [internal.profiles.ProfileCallbackImpl] - Delegating command ‘ON’ for item ‘Konrad_Anwesend’ to handler for channel ‘tr064:subdeviceLan:223534b017:uuid_3A75802409_2Dbccb_2D40e7_2D8e6b_2D3431C4E5430F:macOnline_24_3A18_3A1D_3A8D_3A7E_3AB5’
21:48:05.282 [DEBUG] [re.automation.internal.RuleEngineImpl] - Rule engine not yet started - not executing rule ‘58961ea251’,
21:48:05.282 [DEBUG] [e.internal.common.CombinedClassLoader] - Loaded class “org.openhab.core.thing.binding.ThingHandler” by classloader “org.eclipse.osgi.internal.loader.EquinoxClassLoader@259d669e[org.openhab.binding.tr064:3.1.0(id=242)]” for “[class org.openhab.binding.tr064.internal.Tr064SubHandler]”
21:48:05.283 [DEBUG] [e.internal.common.CombinedClassLoader] - Loaded class “org.openhab.core.thing.ThingStatusInfo” by classloader “org.eclipse.osgi.internal.loader.EquinoxClassLoader@259d669e[org.openhab.binding.tr064:3.1.0(id=242)]” for “[class org.openhab.binding.tr064.internal.Tr064SubHandler]”
21:48:05.283 [DEBUG] [e.internal.common.CombinedClassLoader] - Loaded class “org.openhab.core.thing.ChannelUID” by classloader “org.eclipse.osgi.internal.loader.EquinoxClassLoader@259d669e[org.openhab.binding.tr064:3.1.0(id=242)]” for “[class org.openhab.binding.tr064.internal.Tr064SubHandler]”
21:48:05.284 [DEBUG] [e.internal.common.CombinedClassLoader] - Loaded class “org.openhab.core.thing.binding.ThingHandlerCallback” by classloader “org.eclipse.osgi.internal.loader.EquinoxClassLoader@259d669e[org.openhab.binding.tr064:3.1.0(id=242)]” for “[class org.openhab.binding.tr064.internal.Tr064SubHandler]”
21:48:05.284 [DEBUG] [e.internal.common.CombinedClassLoader] - Loaded class “org.openhab.core.thing.Thing” by classloader “org.eclipse.osgi.internal.loader.EquinoxClassLoader@259d669e[org.openhab.binding.tr064:3.1.0(id=242)]” for “[class org.openhab.binding.tr064.internal.Tr064SubHandler]”
21:48:05.285 [DEBUG] [internal.common.InvocationHandlerSync] - Already in a safe-call context, executing ‘ThingHandler.handleCommand()’ directly on ‘org.openhab.binding.tr064.internal.Tr064SubHandler@33bd027a’.
21:48:05.285 [DEBUG] [inding.tr064.internal.Tr064SubHandler] - Discarding command ON to tr064:subdeviceLan:223534b017:uuid_3A75802409_2Dbccb_2D40e7_2D8e6b_2D3431C4E5430F:macOnline_24_3A18_3A1D_3A8D_3A7E_3AB5, read-only channel
21:48:05.299 [DEBUG] [t.core.internal.GsonMessageBodyWriter] - Failed writing HTTP response, since other side closed the connection
21:48:05.300 [DEBUG] [g.openhab.core.io.rest.SseBroadcaster] - Sending event to sink failed
unfortunately the rules hasn’t been triggered. Maybe the problem is that I’am running in docker. I tried several folder but failed always. Also switching to command recieved failed. The only config which show a trigger logfile was Item status changed from OFF to ON. In this case I’am getting the already known log entry of the relevant trigger.
RuleEngineImpl] - The trigger ‘3’ of rule ‘58961ea251’ is triggered.
08:48:05.051 [DEBUG] [re.automation.internal.RuleEngineImpl] - Rule engine not yet started - not executing rule ‘58961ea251’,
08:48:05.050 [DEBUG] [g.openhab.core.io.rest.SseBroadcaster] - Sending event to sink failed
at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:279) ~[bundleFile:9.4.40.v20210413]
May last rule config:
triggers:
- id: "3"
configuration:
itemName: Konrad_Anwesend
state: ON
previousState: OFF
conditions: []
actions:
- inputs: {}
configuration:
type: application/javascript
script: >-
var Actions = Java.type("org.openhab.core.model.script.actions.Things");
var mailActions = Actions.getActions("mail","mail:smtp:6a99578ade");
var aufgaben = itemRegistry.getItem('FamilienAufgaben').getState()
mailActions.sendMail("konrad.eichstaedt@gmx.de", "Offene Aufgaben", aufgaben);
type: script.ScriptAction
Have you any experience with docker maybe this is the problem? Because the rule which I created with UI I haven’t found any rules file in the openhab subdirectory?
Was this a clean install or did you do an update - from which version?
did you install any additional scripting modules? if yes, deinstall and use the built-in scripting language.
and maybe try to install a milestone build. just in case a file got corrupted.
If you are using MainUI for creating rules, then the rules folder is empty because MainUI uses a json file for storing rules. I prefer .rules files because when you save a rule you see a syntax check in the log. MainUI does not do this.
It was a clean installation of a docker container with openhab 3.1.0 with no special adjustments. I have none additional scripting language installed but I use javascript instead of DSL because I won’t using an installed SMTP Server addon to send E-Mail. Do you know where I have to put a rules file within docker?
