My System was running some days with some rules without technical problems. Yesterday wall power outlet dropped. Startup of my openHAB 3.1.0.M3 seemed to be OK, but the rules I have made did not work as designed. Looking into the log I see : Rule engine not yet started - not executing rule…
None of my rules perform any action.
Is it possible to start the Rule engine manually or else ?
I could not find a solution for this problem…
So I did a DOWNGRADE “sudo apt-get install openhab=3.1.0~M2-1”, without a real success too. (all bindings were lost, or could not be loaded)
Afterwards I did an upgrade again “sudo apt-get install openhab=3.1.0~M3-1”.
This was successful, up to now it seems to me, that the system running again, rules are working and persistance is up again also, which wasn’t before.
