Hey everyone, I’ve been playing around with the system levels to start certain rules, and one very basic is to restart my zigbee controller after openHAB fully finishes starting up. I have copied the yaml to the code brackets below.
I also want to trigger a notification, however neither is the controller rebooted nor is the notification triggered / sent. I’m not exactly certain where it’s going wrong, and I’ve rebooted openHAB several times while looking at the logs and nothing pops up. So I figured I would ask the community before investing more time (and annoying my wife by preventing the rest of the automations from running).
Is anyone else using the system levels to start rules and are the working?
version: 1
rules:
"8f05113853":
label: Start up is done
triggers:
- id: "1"
startlevel: 100
type: StartLevel
actions:
- id: "2"
command: "ON"
itemName: Zigbee2MQTT_Bridge_Restart
type: SendCommand
- id: "3"
message: OpenHAB is back online
type: notification.SendBroadcastNotification
I’m using system levels for various tasks and they generally work fine.
The problem: Currently 100 is reached after everything is up and has been loaded without problems. So if there’s just one binding which fails 100 could never be reached although you’re system might work without problems.
That’s why I usually start my start level rules with system level 70 or 80 if possible.
And for a little more info about how you can determine what start level is reached you can set the logger openhab.event.StartlevelEvent to INFO and transitions to new start levels will be added to events.log. You can also see which start level OH reached from MainUI under Help & About → Technical Information → View Details → systemInfo:
Thank you @rlkoshak ,
Between that information and reading the previously mentioned thread I now understand what prevents the start levels from reaching 100 and sorted the issue on my end had a couple of things stuck when I removed a binding some time ago, hah!
