i got the problem, that the switch state of a hue item doesnt change to OFF when the light is turned off by the wall switch.
So i tried to create a rule that posts an update to the item state when the thing gets offline (power off by wall switch).
Actually the rule doenst work and i get the following error at the logs while the switch state doesnt change.
21:18:10.856 [ERROR] [.internal.handler.ScriptActionHandler] - Script execution of rule with UID 'hue-1' failed: An error occurred during the script execution: index=1, size=1 in hue
rule "Licht Badezimmerdecke aus"
Thing "hue:0210:001788289a8e:1" changed to OFFLINE
createTimer(now.plusSeconds(10)) {
if ("hue:0210:001788289a8e:1" != "ONLINE") {
Hue_BZ_Deckenleuchte_Farbe.postUpdate(OFF)
createTimer(now.plusSeconds(10)) [ |
if (ThingAction.getThingStatusInfo("hue:0210:001788289a8e:1").getStatus().toString() != "ONLINE") {
Thank you! I tried it out immediatly but still get the error:
21:32:58.847 [ERROR] [.internal.handler.ScriptActionHandler] - Script execution of rule with UID 'hue-1' failed: An error occurred during the script execution: index=1, size=1 in hue
In VSCode i get the following warning for ThingAction:
Also i get the following warning in the logs and the item state doesnt change:
20:46:08.635 [WARN ] [core.internal.scheduler.SchedulerImpl] - Scheduled job failed and stopped
java.lang.reflect.UndeclaredThrowableException: null
at com.sun.proxy.$Proxy1280.apply(Unknown Source) ~[?:?]
at org.openhab.core.model.script.actions.ScriptExecution.lambda$0(ScriptExecution.java:82) ~[?:?]
at org.openhab.core.internal.scheduler.SchedulerImpl.lambda$12(SchedulerImpl.java:166) ~[bundleFile:?]
at org.openhab.core.internal.scheduler.SchedulerImpl.lambda$1(SchedulerImpl.java:76) [bundleFile:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
Caused by: org.openhab.core.model.script.engine.ScriptExecutionException: The name 'ThingAction' cannot be resolved to an item or type; line 19, column 13, length 11
at org.openhab.core.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:141) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:992) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:955) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:236) ~[?:?]
at org.openhab.core.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:226) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:216) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:858) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:232) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:991) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:238) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:470) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:256) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:459) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:240) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:202) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.ClosureInvocationHandler.doInvoke(ClosureInvocationHandler.java:47) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.AbstractClosureInvocationHandler.invoke(AbstractClosureInvocationHandler.java:30) ~[?:?]
... 10 more
if (getThingStatusInfo("hue:0210:001788289a8e:1").getStatus().toString() != "ONLINE") {
