Rule errors when upgrading from 2.2 to latest 2.3
Did syntax change in 2.3? I am seeing errors in rules that worked with 2.2.
Error:
2018-05-12 10:55:25.029 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'alarms.rules' has errors, therefore ignoring it: [12,40]: mismatched character '|' expecting ']'
[12,73]: mismatched input ']' expecting '}'
[12,81]: mismatched character '(' expecting ']'
[12,100]: mismatched input ')' expecting '}'
[13,7]: no viable alternative at input 'if'
[18,5]: mismatched input '}' expecting 'end'
Rule:
rule "Alarm Triggered"
  Item Alarms received update
  var boolean gotLock = lock.tryLock()
  try {
    if(gotLock) {
      val alarm = Alarms.members.filter[s|s.lastUpdate("mapdb") !== null].sortBy[lastUpdate("mapdb")].last
      if (alarm.state == OPEN) {
	postUpdate(Notify_Service, "Alarm")
	postUpdate(Notify_Message, alarm.label)
	postUpdate(Notify_Person, "nathan")
  catch(Exception e) {
    logError("Alarms:", "Exception in rule 'Alarms': " + e.toString)
  finally {
    if(gotLock) {
      lock.unlock()
Error:
2018-05-12 10:55:27.374 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'clock.rules' has errors, therefore ignoring it: [6,27]: mismatched character ' ' expecting ']'
[6,37]: no viable alternative at input 'clock'
[8,5]: extraneous input ']' expecting 'end'
Rule:
rule  "Set Z-Wave Clocks"
      Time cron "30 59 23 * * ?"
    logInfo("Z-Wave","Setting Z-Wave Clocks")
    Clock?.members.forEach[DateTime clock |
      clock.sendCommand(ON)
Error:
2018-05-12 10:55:29.453 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'dmx.rules' has errors, therefore ignoring it: [20,37]: mismatched character ' ' expecting ']'
[20,48]: no viable alternative at input 'light'
[22,5]: mismatched input ']' expecting '}'
[24,3]: extraneous input '}' expecting 'end'
Rule:
rule "Pool Random Colors"
  Item Pool_Random received command ON
  //RAPIDLY CHANGE HSB FOR ALL LIGHTS ON
  while(Pool_Random.state == ON) {
    Pool_Lightstrip?.members.forEach[ColorItem light |
      sendCommand(light, (((Math::random * 255).intValue)) + "," + (((Math::random * 100).intValue)) + "," + (((Math::random * 100).intValue)))
    Thread::sleep(200)
Need a space after ā€œ[ā€ and before ā€œ]ā€.
Yep. I was hoping this would be corrected before 2.3 goes to release but I’m not expecting that to happen any more. There is going to be as lot of posts when it does get released and just about every one of my DPsb will need to be updated.
