The state of the switch?
No AtticPowerState what is it?
Its either ON or OFF. Not sure I follow
OK I am on my phone got to get back to work Iāll be home in 2 hours
hehe! no worries Vincent . late night for you!
Hi all, Iām trying to set up a simple rule that aim to switch off the heater when the temperature is >= 22 C.
Below the script, that doesnāt workā¦
I put as trigger the clima setpoint instead of the measured temperature, in order to force the value manually and see if the script work.
Iāve commented all the unnecessary lines in order to simplify, but still no luck.
Can someone help me?
rule "spegnimento_programmato_clima"
when Item Clima_setpont changed
// if (Temperatura_rilevata == NULL) return; // If no temp do nothing
// Calculate states
// if (Clima_acceso_spento.state == NULL) {
// Clima_acceso_spento.sendCommand(OFF) // Initialise climaaccesospento to OFF just in case
// stato_clima = OFF
// } else {
// stato_clima = Clima_acceso_spento.state
val temperature = Temperatura_rilevata as Number
var stato_clima
if (temperature >= 22.0) {
stato_clima = OFF
if (temperature <= 18.0) {
stato_clima = ON
// Do the command
Clima_acceso_spento.sendCommand(stato_clima)
Temperatura_rilevata is an Item. An Item carris a whole bunch of stuff, one of which is the state.
val temperature = Temperatura_rilevata.state as Number
Thank you very much, It works!
Can I ask you which are the other attribuites that I can use on a item? In this case it is .state and It works, but which are the other possibilities?
@rlkoshak Another point: what about to put a timer in order to prevent the heater startup and shutdown continuously? Something like this (I donāt know the sintax and if the function already exist). Is it possible?
stato_clima = OFF
timer(600000); //stop cycling for 10 minutes
stato_clima = ON
name, names of the groups the item is a member of, if itās a group item a list of all itās members, the Itemās label, if you have persistence set up on the item is state at some time in the past, average since, sum since, min/max since, if itās an Item that can be treated as other types (e.g. Color can be treated as a Switch or a Dimmer) you can get the state as one of those other types.
I strongly recommend a review of the rules docs, the Actions docs, and the design pattern posts on this forum.
Thank you @rlkoshak
Iāve red a lot and I was able to fix some problem in the program.
Now there is another problem Iām unable to solve. I add a second temperature sensor and I make the same, identical program with that sensor. With the first sensor the program work, with the second one notā¦!
temp_aqara is the one that does not works.
I think oit can be a problem of variable declaration but I canāt solve it. Can you help me?
rule āspegnimento_programmato_climaā
Item temp_aqara changed
or
Item Temperatura_rilevata changed
// inizializzazione delle variabili
val temperature = Temperatura_rilevata.state as Number //Temperatura_rilevata ĆØ una Item, che puĆ² avere molti attributi. Va specificato l'attributo .state sennĆ² non funziona
val variabile_temp_aqara = temp_aqara.state as Number
var stato_clima
val variabile_setpoint_clima = Clima_setpont.state as Number
// logInfo(variabile_setpoint_clima)
// Calculate states
stato_clima = OFF
else {
// Controllo della temperatura
if (temperature >= 23.0) {
stato_clima = OFF
variabile_setpoint_clima = 19
if (temperature <= 20.0 || variabile_temp_aqara <= 20) {
stato_clima = ON
variabile_setpoint_clima = 23
// Do the command
// Timer non funzionante, da sistemare createTimer(now.plusSeconds(60)) [ ]
Clima_setpont.sendCommand(variabile_setpoint_clima)
here the log
2020-12-20 19:49:53.150 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'temperature.rules', using it anyway:
Type cannot be derived
Assignment to final variable
2020-12-20 19:49:53.212 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'temperature.rules'
2020-12-20 19:50:54.061 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'temperature.rules', using it anyway:
2020-12-20 19:50:54.114 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'temperature.rules'
This means you have a variable defined and do not five it enough information for the rules ending to determine what itās type is. Iām going to guess that itās stato_clima
. There is nothing there to tell it what type of variable it is. You need to tell it, either by assigning something to it like in the other variables or give it a type on definition.
var OnOfftype stato_clima
When you define something as a value (i.e. using val
) you are saying āthis is a constant, it should never change.ā consequently, you should never see that value on the left side of a =
because reassigning a value to the value is changing it.
You have variable_setpoint_clima on the left side of an =
in at least two places. If these lines are valid, which they appear to be, variable_setpoint_clima needs to be declared as a variable (i.e. var
), not a value.
Since itās really cold here now I thought Iād bring this thread back to the original topic of engine heaters.
I would like to share the latest version of my rule. The changes are:
- Its adapted to OH3, which means that some logic moved out of the script itself and also that some date/time related stuff had to change
- My wife is now on a weekly schedule with different start times each day, so I added functionality for that
Rule follows. I kick it off at 5 every morning.
var int minutes = (60 - (Utetemperatur.state as QuantityType<Number>).doubleValue * 6).intValue
if(minutes > 120) {
minutes = 120
var departure = now.with(LocalTime.of(8, 00))
switch(now.getDayOfWeek()) {
case MONDAY: {
departure = now.with(LocalTime.of(7, 15))
case TUESDAY: {
departure = now.with(LocalTime.of(7, 45))
case WEDNESDAY: {
departure = now.with(LocalTime.of(5, 45))
case THURSDAY: {
departure = now.with(LocalTime.of(8, 45))
case FRIDAY: {
departure = now.with(LocalTime.of(6, 15))
default: {
logError("engineheater", "This rule is not supposed to be activated today!")
createTimer(departure.minusMinutes(minutes)) [|
Motorvarmare.sendCommand(ON)
Itās probably worth while when posting Rules like these to the forum to post the full rule from the code tab instead of just the Script Actions. That way we can all see the triggers and conditions too. If itās not a UI rule, include the rule/when/then/end stuff too. Iām finding a lot of users on the forum are not quite understanding the difference and if we can try to be consistent it might be easier for them.
My thinking was that this is not a rule that anyone would want to use out-of-the-box anyway, because you have to tweak it to fit your needs. But you may be right, here comes the entire rule:
triggers:
- id: "3"
configuration:
time: 05:00
type: timer.TimeOfDayTrigger
conditions:
- inputs: {}
configuration: {}
type: ephemeris.WeekdayCondition
actions:
- inputs: {}
configuration:
type: application/vnd.openhab.dsl.rule
script: >
if(minutes > 120) {
minutes = 120
case MONDAY: {
case TUESDAY: {
case WEDNESDAY: {
case THURSDAY: {
case FRIDAY: {
default: {
logError("engineheater", "It's some other day!")
type: script.ScriptAction
By the way: As you see Iāve used ephemeris here to only run when itās a week day. Is there any way to tell it to run only on week days that are not holidays? I see a check box for if āitās a holidayā but not the opposite.
It can be informative to see how the rule is triggered. It may not be exactly what people want but seeing the trigger will give them ideas for how to set it up. And Iām amazed at the number of users who are having difficulty understanding how rules are put together in the UI. More examples is better.
There is a PR to add that. I canāt remember if itās been merged or not but I would expect to see that in OH 3.1, unless there is a problem with doing that.
Ok, now it turns out it didnāt work as I expected anyway. Today it is saturday and the engine heater was turned on. Have I misunderstood the ephemeris āit is a weekdayā? I thought it meant that it would not be activated on saturdays or sundays? @rlkoshak, you got any idea?
By the way, is there any way of exiting a rule prematurely? In my switch, where I print out an error if itās not monday-friday, it seems it would be a good idea to put something that simply aborts the script.
Double check the Ephemeris config to verify that the weekend days are set. In scratchpad rule log out the results to calls to isWeekend.
The best way to handle that is to put it into the condition so the rule doesnāt run in the first place.
Yep, it looks alright in Ephemeris config (saturday and sunday are checked). How do you mean I could check this in the scratchpad?
From the developer sidebar you can bring up a scratchpad Script where you can type in and run some rules code without going to the touble if creating a full rule. It is a great place to quickly get stuff out to see what happens or test things or generate events to test something.
