Rule for a "Long press" switch does not work
I would like to implement a rule to check if a button of a switch is pressed “Long”. Therefore I use following rule:
var Timer tTaste = null rule "Taste auswerten"
rule "WohnenSchlafenTaster_long"
	Item Taster_Wohnen_Schlafen_Eingang_Taster_Wohnen_Schlafen_Eingang changed
	tTaste?.cancel
	if(newState == ON) {
		tTaste = createTimer(now.plusNanos(2000000000),[| // 2000 Millisekunden
		// Befehl: langer Tastendruck erkannt
		logInfo("Taster WohnenSchlafen", "langer Tastendruck erkannt")
		KNX_Device_Aktor_A3_Wohnen_Licht_Esstisch.sendCommand(ON)
	} else {
	if(!(tTaste.hasTerminated)) {
		// Befehl: kurzer Tastendruck erkannt
		logInfo("Taster WohnenSchlafen", "kurzer Tastendruck erkannt")
		KNX_Device_Aktor_A3_Licht_Wohnen_Wohnen_Licht_Durchgang.sendCommand(ON)
which gives me this error log:
 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'WohnenSchlafenTaster_long.rules'
 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'WohnenSchlafenTaster_long.rules' has errors, therefore ignoring it: [3,1]: mismatched input 'rule' expecting 'when'```
Can someone tell me pls what this error means and how I need to change the rule?
Thanks!
var Timer tTaste = null rule “Taste auswerten”
rule “WohnenSchlafenTaster_long”
You added rule “Taste auswerten” behind the timer definition (on that same line). It expects a when on the next line and is complaining that it finds rule "WohnenSchlafenTaster_long" instead.
So remove rule "Taste auswerten".
You can do } else if {
yeah thanks for the inputs - it works now!
