Everyswitch that I will have will be mqtt based. Is there a variable that I could use in rules that, when a switch’s state is updated, that rule runs ?
If a bindings gets a command or a status update from its bus, it will update the corresponding item. In openHAB you can let trigger rules dependent on updates or changes. The main difference is, if there is an update from oldstate ON
to newstate ON
, update will trigger, but changed will not. You can narrow the updates/changes down with a given state:
rule "my rule"
Item myItem received update //will trigger whenever the item myItem receives an update
or
Item myItem received update ON //will trigger whenever the item myItem receives an update to state ON
or
Item myItem changed to OFF //will trigger if item myItem changes from whatever to OFF
or
Item myItem changed from ON //will trigger if item myItem changes from ON to whatever
or
Item myItem changed from OFF to ON //will trigger if item myItem changes from OFF to ON
// do something...
Please keep in mind that even a switch item has more than two states, namely OFF
, ON
and uninitialized
, so if you let trigger with changed from OFF to ON
the rule will not trigger the first time, the item is updated, 'cause it changes from uninitialized
to ON
(or OFF
As a third trigger, opanHAB can trigger to commands (but not simple status messages):
rule "my rule"
Item myItem received command //trigger only, if it is a command
// do something
The main difference between update
and command
is the action in a rule. You can do a
sendCommand(item,value)
which will send a command
to the item (and this command will be sent from the item to each binding which is bound to it)
In contrast postUpdate(item,value)
will cause an update
of the item, this will not be sent to the bindings. But the UI will display this update for instance.
Thanks for your reply. Udo_Hartman
I think that is formulated my question badly.
What I mean is, how can I have a rule that will get all switches… like this
rule "my rule"
AllItems received update …
But, since, i read that I could use groups to do what I want.
Not sure yet
A little bit dangerous to trigger all updates, but sure you can putt all items in a group and trigger on updates to the group. What would be the scope?
All Switches will have a unique ID and dont want to set a per ID/switch rule.
So I was thinking a general rule that would grab the id of the switch and do a action apon it.
maybe i’m not doing it right
Take a look at the following post:
More specifically, under the section called “Group and Filter” you will find a rule called “Override Lights” that I believe shows how to do what you want (that is, pick out which switch was operated out of a group of switches).
Indeed, the posting that @KjetilA links to does indeed show how you can get the most recently updated Item from a group but I want to point out a couple of caveats.
Item MyGroup received update
Yes, I think that tests are in order
I already have persistense setup. I will add the switches to a pre-determined group and add that group to the persistence setup.
Thank you for all your help ! really appreciate it !
