Hi community!
I have created a rule to read the values from my TFA WeatherHub sensors into openHAB3.
This rule is run every 7 minutes and executes the script below. The values are only updated every 7 minutes by the TFA WeatherHub.
This script needs to be adapted with:
- your “Phone ID” from the WeatherHub App
- the openHAB item names of your manually created items to store the values
- the sensor names of your connected sensors (which you can manually edit in the app)
For me, this code worked stable up to now, but I am happy to get improvements from you.
I would recommend to test the regex results as indicated in the code.
You do not need to install a binding for this.
Greetings, Karsten
Code:
var logger = Java.type('org.slf4j.LoggerFactory').getLogger('org.openhab.rule.WeatherHub');
var client = java.net.http.HttpClient.newBuilder().build();
// Enter uri with your phoneid, can be found in the settings of the TFA WeatherHub App
var uri = "https://measurements.mobile-alerts.eu/Home/SensorsOverview?phoneid=000111222333";
// get data from mobile-alerts
var request = java.net.http.HttpRequest.newBuilder()
.GET()
.uri(java.net.URI.create(uri))
.header("Content-Type", "text/html")
.build();
var htmlResponseBody = client.send(request, java.net.http.HttpResponse.BodyHandlers.ofString()).body();
// function to extract and format data
this.getMeasurement = function(regExPattern, itemName)
var regEx1 = new RegExp(regExPattern, 'm');
var regRes = regEx1.exec(htmlResponseBody);
var measurement = null;
if((regRes != null) && (regRes[1] != null))
measurement = regRes[1]
// Remove units
measurement = measurement.replace(" C", "").replace("%", "").replace(",", ".")
// replace unavailable values with null
if(measurement == "---") {measurement = null}
// Log and save measurements
logger.info("Measurement for item \"" + itemName + "\" is: " + measurement);
if (measurement != null)
// normal values sent as command
events.sendCommand(itemName, measurement);
else
// null values cannot be commands
events.postUpdate(itemName, NULL);
// Names must be adapted to your sensor names and language
// regex Expressions can be tested at https://regex101.com/
// typical regular expression syntyx is: "Location[\\s\\S]Sensorname[\\s\\S]*?<h4>(.+)<\/h4>"
this.getMeasurement("ZuHause[\\s\\S]*?Temp In[\\s\\S]*?<h4>(.+)<\/h4>", "itTemperaturBad");
this.getMeasurement("ZuHause[\\s\\S]*?Temp 1[\\s\\S]*?<h4>(.+)<\/h4>", "itWeatherHubTemp1");
this.getMeasurement("ZuHause[\\s\\S]*?Temp 2[\\s\\S]*?<h4>(.+)<\/h4>", "itWeatherHubTemp2");
this.getMeasurement("ZuHause[\\s\\S]*?Temp 3[\\s\\S]*?<h4>(.+)<\/h4>", "itWeatherHubTemp3");
this.getMeasurement("ZuHause[\\s\\S]*?Hum In[\\s\\S]*?<h4>(.+)<\/h4>", "itHumidityBad");
this.getMeasurement("ZuHause[\\s\\S]*?Hum 1[\\s\\S]*?<h4>(.+)<\/h4>", "itWeatherHubHum1");
this.getMeasurement("ZuHause[\\s\\S]*?Hum 2[\\s\\S]*?<h4>(.+)<\/h4>", "itWeatherHubHum2");
this.getMeasurement("ZuHause[\\s\\S]*?Hum 3[\\s\\S]*?<h4>(.+)<\/h4>", "itWeatherHubHum3");
this.getMeasurement("ZuHause[\\s\\S]*?Zeitpunkt[\\s\\S]*?<h4>(.+)<\/h4>", "itWeatherHubTime1");
this.getMeasurement("MitWassersensor[\\s\\S]*?Zeitpunkt[\\s\\S]*?<h4>(.+)<\/h4>", "itWeatherHubTime2");
//this.getMeasurement("MitWassersensor[\\s\\S]*?Temperatur[\\s\\S]*?<h4>(.+)<\/h4>", "itWeatherHubTempS1");
//this.getMeasurement("MitWassersensor[\\s\\S]*?Luftfeuchte[\\s\\S]*?<h4>(.+)<\/h4>", "itWeatherHubHumS1");
this.getMeasurement("MitWassersensor[\\s\\S]*?Wassersensor[\\s\\S]*?<h4>(.+)<\/h4>", "itWeatherHubWassersensor");
