I’m looking for a way to detect whether a shutter has been manually pressed or if the position was approached manually. Unfortunately, this informaiton does not provide the actuator.
Does somebody has any idea?
I had already set myself variable to recognize whether I am driven automatically. Unfortunately, I’m not there any further.
The Rule does not work:
rule "Rolladen"
when Rollo_EG_WZ_EuI received update
if (Rolladen_EuI_Auto_gefahren.state==ON) {
sendCommand(Rolladen_EuI_Auto_gefahren, OFF)
logInfo(“Rolladen EuI”, “Auto beleibt aktiv”)
else
sendCommand(Rolladen_EuI_Auto, OFF)
logInfo(“Rolladen EuI”, “Auto wird deaktiviert”)
Openhab.log:
Cannot retrieve item ‘Rolladen_EuI_Auto’ for widget org.eclipse.smarthome.model.sitemap.Switch
rule "Rolladen EuI Automikmodus pruefen"
when Rollo_EG_WZ_EuI changed
else
i test changed or received update but i became the following error notifiction in the log:
2017-08-22 22:50:46.685 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model ‘test.rules’ is either empty or cannot be parsed correctly!
2017-08-22 22:50:46.993 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model ‘test.rules’ has errors, therefore ignoring it: [275,7]: no viable alternative at input ‘Rollo_EG_WZ_EuI’
where is the mistake? Thanks for your help!
ThomyTP
