i have generated a rule with Habpanel, since 2 years, and with the latest 2.5 Version of openhab it doesnt work anymore.
// This rule file is autogenerated by HABmin.
// Any changes made manually to this file will be overwritten next time HABmin rules are saved.
Imports
import org.openhab.core.library.types.*
import org.openhab.core.persistence.*
import org.openhab.model.script.actions.*
import org.joda.time.*
// Global Variables
rule "Steckerleiste Schlafzimmer um 2:00 Uhr ausschalten"
Time cron "0 * * * * ?"
if ((((new LocalTime().getLocalMillis()) >= (new LocalTime(2, 0, 0, 0).getLocalMillis())) && ((new LocalTime().getLocalMillis()) <= (new LocalTime(2, 30, 0, 0).getLocalMillis())) && (flagitemtvbed.state == ON))) {
sendCommand(Power_FF_Bed, OFF)
I noticed it after I rewrote the rule because I haven’t used it for a long time.
i tried to change it to:
Item MartinsPhone received update OFF or
Time cron "0 0 2 * * ?"
if (flagitemtvbed.state == ON && Power_FF_Bed.state == ON) {
Power_FF_Bed.sendCommand(OFF)
can someone help me to get this rule working again, it should turn off a sonoff pow after 2 o clock or when my phone is not in the wlan, maybe someone can show me a better solution to do this with a rule.
I probably made a mistake because I previously commented everything out with // and have no backup of the original file
I have the following item connected to the guestClients channel, to detect if any guests connect to the network (this is using the latest snapshot binding, not the default one from PaperUI):
Number nWifiGuestClients "Default Site: Guest Clients [%d]" { channel="unifi:site:home:default:guestClients" }
In a rule, I then simply check to see if the number has changed:
Item nWifiGuestClients changed
Perhaps change your MartinsPhone trigger to:
Item MartinsPhone changed to OFF
(As @rossko57 says, for the particular rule you have shown you don’t need any of those imports.)
EDIT: Actually, also double check your cron expression. To trigger at 2am I would use:
I think it would be best to scrap the rule and start from scratch. Explain what you would like to happen in the rule and don’t get hung up on how you think it should be written . It seems like you want the television in your bedroom to turn off at any time between 2am and some other time, say 5am, if the television is on and your phone is on your network. How often should these conditions be checked? Here is an example that checks every 5 minutes from 2-5am…
or
Time cron "0 0/5 2-4 * * ?"
if (flagitemtvbed.state == ON && Power_FF_Bed.state == ON && (new DateTimeType).zonedDateTime.getHour > 2 && (new DateTimeType).zonedDateTime.getHour < 5) {
thank you for this example, and how do i need to change the rule when i will change the time from 2 am to 5 pm? Can i change it to <17 (german time format)?
i should power off the powersocket of the tv when i am at work ore not at home, but it should be on when i am at home from work earlier ore in holidays, therefore I have the query with my cell phone whether I am at home. So your rule is the right one i need
It is not clear what you mean. If you want 5pm, it would be 17 in 24-hour time format, which is what the getHour method returns. You would need to change the cron expression too.
I’m glad I could help, but if you would provide details on what you’d like the rule to do, then it would be much easier to help you out.
i work from 8am to 5pm, but i will start the rule at 2 am at night, because i dont need it on when i sleep.
flagitemtvbed is a dummy switch to turn on and off the rule (better said stop the execution of the rule)
Power_FF_Bed is a sonoff pow, on this the tv is plugged in
its good when the rule is checking every 5 min if the MartinsPhone is ON (than i am at home and the Power_FF_Bed should turn ON again that i can watch TV )
thank you for this rule, i have now setup like this:
rule "turn off powerplug"
or
Time cron "* 0/5 2-15 * * ?"
if (flagitemtvbed.state == ON && Power_FF_Bed.state == ON && (new DateTimeType).zonedDateTime.getHour > 2 && (new DateTimeType).zonedDateTime.getHour < 19) {
logInfo("Steckerleiste TV Schlafzimmer","Steckerleiste Schlafzimmer ausgeschalten")
rule "turn on powerplug"
Item MartinsPhone received update ON
or
Time cron "* 0/5 19-23 * * ?"
if (flagitemtvbed.state == ON && Power_FF_Bed.state == OFF && (new DateTimeType).zonedDateTime.getHour > 19 && (new DateTimeType).zonedDateTime.getHour < 24) {
logInfo("Steckerleiste TV Schlafzimmer","Steckerleiste Schlafzimmer eingeschalten")
Power_FF_Bed.sendCommand(ON)
Maybe i will add an option to ckeck if it is mo-fr also, and if it is sa-so it should not turn off the powerplug
