Hi, I am not a software developer, therefore need some support from you. Many thanks in advance…
I have a hooked up a gas and water sensor to a binary actuator (KNX).
The scalings are:
- water: each Impulse represents one liter consumption
- gas: each Impulse represents 0.01m³ consumption
Platform information:
- Hardware: pine64
- OS: Ubuntu 16.04.4 LTS (openHABian)
- Java Runtime Environment: openjdk version “1.8.0_152”
- openHAB version: openHAB 2.3.0 Build #1241
configurations
rrd4j.persist
Strategies {
everyMinute : "0 * * * * ?"
everyHour : "0 0 * * * ?"
everyDay : "0 0 0 * * ?"
default = everyChange
Items {
Gas_pulse : strategy = everyChange, restoreOnStartup
Gas_scale : strategy = everyChange, restoreOnStartup
Water_pulse : strategy = everyChange, restoreOnStartup
Water_scale : strategy = everyChange, restoreOnStartup
knx.items
Group gGas
Number Gas_pulse "Gas (Impuls=0.01m³) [%.0f Imp]" <gas> (gGas) { channel="knx:device:bridge:binaryinput2:Gas" }
Number Gas_scale "Gas [%.3f m³]" <gas> (gGas)
Number Gas_Last_H "Gas letzte Stunde [%.3f m³]" <gas> (gGas)
Number Gas_Last_3H "Gas letzten 3 Stunde [%.3f m³]" <gas> (gGas)
Number Gas_Last_D "Gas letzter Tag [%.3f m³]" <gas> (gGas)
Number Gas_meter "Gas Zählerstand[%.3f m³]" <gas> (gGas)
Number Gasprice "Gaspreis" <gas> (gGas)
DateTime Gas_LastTime "Letzter Gas Vebrauch [%1$td.%1$tm.%1$tY %1$tT]" <time>
Group gWater
Number Water_pulse "Wasser (Impuls=1l) [%.0f Imp]" <water> (gWater) { channel="knx:device:bridge:binaryinput2:Wasser" }
Number Water_scale "Wasser [%.3f m³]" <water> (gWater)
Number Water_Last_H "Wasser letzte Stunde [%.3f m³]" <water> (gWater)
Number Water_Last_3H "Wasser letzten 3 Stunden [%.3f m³]" <water> (gWater)
Number Water_Last_D "Wasser letzter Tag [%.3f m³]" <water> (gWater)
Number Water_meter "Wasser Zählerstand [%.3f m³]" <water> (gWater)
Number Waterprice "Wasserpreis" <water> (gWater)
DateTime Water_LastTime "Letzter Wasser Vebrauch[%1$td.%1$tm.%1$tY %1$tT]" <time>
knx.sitemap
sitemap knx label="KNX Schmart Mäter" {
Frame label="Gas" {
Text item=Gas_pulse
Text item=Gas_scale
Text item=Gas_Last_H
Text item=Gas_Last_3H
Text item=Gas_Last_D
Text item=Gas_meter
Text item=Gas_LastTime
Chart item=Gas_scale period=4h refresh=300
Frame label="Wasser" {
Text item=Water_pulse
Text item=Water_scale
Text item=Water_Last_H
Text item=Water_Last_3H
Text item=Water_Last_D
Text item=Water_meter
Text item=Water_LastTime
Chart item=Water_scale period=4h refresh=300
gas.rules
rule "Gas smart metering" //divide by 100, because each impuls=0.01m3, add also offset
Item Gas_pulse changed
Gas_scale.postUpdate(Gas_pulse.state as Number / 100)
logInfo("Rules", "Gas impuls scaled in m³: " + Gas_scale.state)
Gas_meter.postUpdate(Gas_pulse.state as Number / 100 + 16685.299)
logInfo("Rules", "Gas meter value in m³" + Gas_meter.state)
Gas_LastTime.postUpdate(new DateTimeType())
logInfo("Rules", "Gas last update" + Gas_LastTime.state)
Gas_Last_H.postUpdate(Gas_pulse.deltaSince(now.minusHours(1),"rrd4j") / 100)
logInfo("Rules", "Gas last hour scaled to: " + Gas_Last_H.state)
Gas_Last_3H.postUpdate(Gas_pulse.deltaSince(now.minusHours(3),"rrd4j") / 100)
logInfo("Rules", "Gas last 3 hours scaled to: " + Gas_Last_3H.state)
Gas_Last_D.postUpdate(Gas_pulse.deltaSince(now.minusDays(1),"rrd4j") / 100)
logInfo("Rules", "Gas day scaled to: " + Gas_Last_D.state)
water.rules
rule "Water smart metering" //divide by 1000, because each impuls=0.001m3, add also offset
Item Water_pulse changed
Water_scale.postUpdate(Water_pulse.state as Number / 1000)
logInfo("Rules", "Water impuls scaled in m³: " + Water_scale.state)
Water_meter.postUpdate(Water_pulse.state as Number / 1000 + 399.955 - 0.005)
logInfo("Rules", "Water meter value in m³" + Water_meter.state)
Water_LastTime.postUpdate(new DateTimeType())
logInfo("Rules", "Water last update" + Water_LastTime.state)
Water_Last_H.postUpdate(Water_pulse.deltaSince(now.minusHours(1),"rrd4j") / 1000)
logInfo("Rules", "Water last hour scaled to: " + Water_Last_H.state)
Water_Last_3H.postUpdate(Water_pulse.deltaSince(now.minusHours(3),"rrd4j") / 1000)
logInfo("Rules", "Water last 3 hours scaled to: " + Water_Last_3H.state)
Water_scale_D.postUpdate(Water_pulse.deltaSince(now.minusDays(1),"rrd4j") / 1000)
logInfo("Rules", "Water day scaled to: " + Water_scale_D.state)
- logs
[ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Water smart metering': null
[ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Gas smart metering': null
2018-03-26 09:54:22.952 [INFO ] [eclipse.smarthome.model.script.Rules] - Gas impuls scaled in m³: 28.84000000
2018-03-26 09:54:22.971 [INFO ] [eclipse.smarthome.model.script.Rules] - Gas meter value in m³16714.14900000
2018-03-26 09:54:22.981 [INFO ] [eclipse.smarthome.model.script.Rules] - Gas last update2018-03-26T09:54:06.813+0200
2018-03-26 09:54:22.997 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Gas smart metering': null
2018-03-26 09:54:22.923 [vent.ItemStateChangedEvent] - Gas_pulse changed from 2884.0 to 2885.0
2018-03-26 09:54:22.947 [vent.ItemStateChangedEvent] - Gas_scale changed from 28.84000000 to 28.85000000
2018-03-26 09:54:22.967 [vent.ItemStateChangedEvent] - Gas_meter changed from 16714.13900000 to 16714.14900000
2018-03-26 09:54:23.007 [vent.ItemStateChangedEvent] - Gas_LastTime changed from 2018-03-26T09:54:06.813+0200 to 2018-03-26T09:54:22.974+0200
- Issues
- not getting a value for:
and
I assume, there is an error with my rrd4j persistence, because the chart in the sitemap does not show all values.
In addition to this post,
- I would like to extend both rules with calculations of gas/water pricing.
- I would like to have a chart, where the gas/water will be reseted, if lets say no consumption for 5 minutes exists. The chart should then identify consumption by peaks (like an impulse) to see for example the toilet flush needs 9l water and the short press only 4l or the washing machine needs 25l.
… but this can be developed later on, by help of all of you.
…maybe there are already some usable code snippets for that…
thanks for any reply…
