I cleared valuecolor, it did not help: Text item = Temperature_8302000000000000 label = "Bedroom1 [% s ° C]"
2019-07-05 10:52:46.989 [WARN ] [org.eclipse.jetty.server.HttpChannel] - /basicui/app
at org.eclipse.smarthome.ui.internal.items.ItemUIRegistryImpl.convertStateToWidgetUnit(ItemUIRegistryImpl.java:431) ~[?:?]
at org.eclipse.smarthome.ui.internal.items.ItemUIRegistryImpl.getLabel(ItemUIRegistryImpl.java:404) ~[?:?]
at org.eclipse.smarthome.ui.basic.internal.render.AbstractWidgetRenderer.preprocessSnippet(AbstractWidgetRenderer.java:121) ~[?:?]
at org.eclipse.smarthome.ui.basic.internal.render.TextRenderer.renderWidget(TextRenderer.java:61) ~[?:?]
at org.eclipse.smarthome.ui.basic.internal.render.PageRenderer.renderWidget(PageRenderer.java:194) ~[?:?]
at org.eclipse.smarthome.ui.basic.internal.render.PageRenderer.processChildren(PageRenderer.java:160) ~[?:?]
at org.eclipse.smarthome.ui.basic.internal.render.PageRenderer.processChildren(PageRenderer.java:181) ~[?:?]
at org.eclipse.smarthome.ui.basic.internal.render.PageRenderer.processPage(PageRenderer.java:124) ~[?:?]
at org.eclipse.smarthome.ui.basic.internal.servlet.WebAppServlet.service(WebAppServlet.java:189) ~[?:?]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790) ~[29:javax.servlet-api:3.1.0]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:865) ~[?:?]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:535) ~[?:?]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) ~[?:?]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:146) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) ~[?:?]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:132) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:257) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1595) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:255) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1317) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:293) ~[?:?]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:203) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:473) ~[?:?]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1564) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:201) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1219) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:144) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) ~[?:?]
at org.eclipse.jetty.server.Server.handle(Server.java:531) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:352) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:260) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:281) [75:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:102) [75:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:118) [75:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:333) [87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:310) [87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:168) [87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:126) [87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:366) [87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:762) [87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:680) [87:org.eclipse.jetty.util:9.4.11.v20180605]
changed only one line in sitemaps, others did not touch.
Initially, I am worried about the possibility of working with an item value without dimension. This also did not work for the rule:
if (Temperature_8302000000000000.state <40) {
logInfo (“Records when device mobile1 was last seen”, “Temperature_8302000000000000.state =” + Temperature_830200000000000000.state, “IF”)
That’s right, if you do this:
Text item = Temperature_8302000000000000 label = “Bedroom1 [% .1f]”
Then the value for the item will be displayed in the basicUI, but there will be no “° C” dimension.
For example, it did not work:
Text item = Temperature_8302000000000000 label = “Bedroom1 [% .1f] ° C”
Of course it doesn’t work. Once again spaces have been aďded. We’ve already done this part.
[% .1f] is broken, there should not be a space between % and the . dot
[%.1f] is correct
You need to figure out why you keep getting extra spaces.
Without an example, it was not clear. Now I understand you, it was necessary to do this:
Text item=Temperature_8302000000000000 label=“Bedroom1 [%.1f°C]”
You are allowed spaces in the [ format ] but not in the special control parts with a %
Example
[%.1f degrees centi]
Those spaces are just part of some text.
What was the great question? There have been so many.
Because of that Item type.
As we discussed before, Number:Dimensionless does have units of measurement, typically % percent.
The Items state is therefore something like 27%
You cannot compare 27% with 22. “22 what? Parts per million?”
You either have to strip the % off the 27, or add a % to the 22
No, I have no idea why you would put your apparent temperature reading into a Number:Dimensionless type. People would usually use either a Number:Temperature or a plain Number.
Why then in logs it is not written% after value? It worked with temperature and wrote:
2019-07-01 14: 05: 50.319 [INFO] [vice ControllerDS18B20 was last seen] - Temperature_28a06224020000e1.state = 56.31 ° C
Logs write in rule:
logInfo("Records when device ControllerDS18B20 was last seen", "Temperature_28a06224020000e1.state=" + Temperature_28a06224020000e1.state)
Probably because you haven’t assigned it a unit. Just because people usually use Number:Dimensionless as a percentage doesn’t meant it has to be.
Number:Dimensionless represents a proportion, so “3 to 1” would be a valid sort of value to represent. The state of the Item can only hold one number, so we might store that as just 3, with a blank unit.
It’ is still a Number:Dimensionless, and you still cannot do the apples/oranges comparison with a plain Number.
You seem to be making it difficult for yourself by choosing to store some temperature reading in a Number:Dimensionless Item. Maybe it is time to review that decision.
I am trying to approach the setting of OH2 in a systematic and uniform way.
My approach, which is not clear how to implement:
In the items I create an item with the desired icon (temperature, humidity, pressure, voltage). But the value of the item should not keep dimension.
in sitemaps I configure the output in basicui what dimension to display in the user interface
in the rules, use for comparison only the value of .state for all items.
For example, the readings from the humidity sensor do not work according to the temperature example, the rules do not work if the comparison without dimension does not work:
rule "Records when device mobile1 was last seen"
Item Temperature_83020000000000 received update or
Item Humidity_8302000000000000 received update or
Item Voltage_8302000000000000 received update
logInfo ("Records when device mobile1 was last seen", "BEGIN")
logInfo ("Records when device mobile1 was last seen", "Temperature_8302000000000000.state =" + Temperature_830200000000000000.state)
logInfo ("Records when device mobile1 was last seen", "Humidity_8302000000000000.state =" + Humidity_830200000000000000.state)
postUpdate (Mobile1_LastUpdate, new DateTimeType ())
logInfo ("Records when device mobile1 was last seen", "Temperature_8302000000000000.state =" + Temperature_830200000000000000.state + "IF")
if (Humidity_8302000000000000.state <40) {
logInfo ("Records when device mobile1 was last seen", "Humidity_8302000000000000.state =" + Humidity_830200000000000000.state + "IF")
logInfo ("Records when device mobile1 was last seen", "END")
In the logs:
2019-07-08 13: 52: 06.447 [INFO] [ds when device mobile1 was last seen] - BEGIN
2019-07-08 13: 52: 06.448 [INFO] [ds when the device mobile1 was last seen] - Temperature_8302000000000000.state = 21.2
2019-07-08 13: 52: 06.448 [INFO] [ds when device mobile1 was last seen] - Humidity_83020000000000.state = 53.5
2019-07-08 13: 52: 06.449 [INFO] [ds when device mobile1 was last seen] - Temperature_8302000000000000.state = 21.2 IF
2019-07-08 13: 52: 06.449 [INFO] [ds when device mobile1 was last seen] - END
I expected with this setting that the line will be displayed in the log: 2019-07-08 13: 52: 06.448 [INFO] [ds when device mobile1 was last seen] - Humidity_83020000000000.state = 53.5 IF
