I created already several rules which are working ok.
But my latest rule, gets executed 30-40 seconds after the trigger took place…
Rule
import org.openhab.core.library.types.DecimalType
var diameter = 20 // cm
var hoogte = 25 // cm
var Number measure_cm
var Number waterpeil
var Number inhoudTon
var Number inhoud
var Number inhoudPercrule "calculate water content"
Item MQTT_distance changed
logInfo(“regenton”, “executing rule”)measure_cm = (MQTT_distance.state as DecimalType) / 10 inhoudTon = (3.14 * ((diameter / 2) * (diameter / 2)) * hoogte) / 1000 waterpeil = hoogte - (measure_cm) inhoud = (3.14 * ((diameter / 2) * (diameter / 2)) * waterpeil) / 1000 inhoudPerc = (inhoud / inhoudTon) * 100 logInfo("regenton", "inhoud: " + inhoudTon + " liter") logInfo("regenton", "waterpeil: " + waterpeil + " cm") logInfo("regenton", "inhoud NU: " + inhoud + " liter") logInfo("regenton", "inhoud NU: " + inhoudPerc + " %") MQTT_water_content_full.postUpdate(inhoudTon) MQTT_distance_cm.postUpdate(measure_cm) MQTT_waterpeil.postUpdate(waterpeil) MQTT_water_content_current.postUpdate(inhoud) MQTT_water_content_current_perc.postUpdate(inhoudPerc)
log:
2017-08-15 20:26:38.710 [ItemStateChangedEvent ] - MQTT_distance changed from 176 to 32
2017-08-15 20:27:19.737 [INFO ] [ipse.smarthome.model.script.regenton] - executing rule
2017-08-15 20:27:19.905 [INFO ] [ipse.smarthome.model.script.regenton] - inhoud: 7.85 liter
2017-08-15 20:27:19.910 [INFO ] [ipse.smarthome.model.script.regenton] - waterpeil: 21.80000000 cm
2017-08-15 20:27:19.916 [INFO ] [ipse.smarthome.model.script.regenton] - inhoud NU: 6.8452 liter
2017-08-15 20:27:19.924 [INFO ] [ipse.smarthome.model.script.regenton] - inhoud NU: 87.20000000 %
When I remove the formulas, the rule is executed immediately… the formulas aren’t that difficult
Are there maybe better ays to do these kind of things?
Pi
and sqrt
are also not working with import java.lang.Math.*
