Dear all
while starting OH 1.8.3 I get occasionally errors (see line 7 and 11 in following log) but the affected file is both existing and has content.
Is this a known problem? If yes how can it be fixed?
Thanks & Regards
John
2016-08-28 10:33:01.451 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'airflow.rules'
2016-08-28 10:33:02.764 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'bwm.rules'
2016-08-28 10:33:02.779 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'jalousien.rules'
2016-08-28 10:33:02.811 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'lights.rules'
2016-08-28 10:33:03.326 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'notifications.rules'
2016-08-28 10:33:03.326 [WARN ] [c.internal.ModelRepositoryImpl] - Configuration model 'notifications.rules' is either empty or cannot be parsed correctly!
2016-08-28 10:33:03.326 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'oneline.rules'
2016-08-28 10:33:03.342 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'reset.rules'
2016-08-28 10:33:03.357 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'status.rules'
2016-08-28 10:33:03.623 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'switches.rules'
2016-08-28 10:33:03.811 [ERROR] [r.i.DefaultResourceDescription] - notifications.rules (Das System kann die angegebene Datei nicht finden)
java.io.FileNotFoundException: notifications.rules (Das System kann die angegebene Datei nicht finden)
at java.io.FileInputStream.open0(Native Method) ~[na:1.8.0_101]
at java.io.FileInputStream.open(Unknown Source) ~[na:1.8.0_101]
at java.io.FileInputStream.<init>(Unknown Source) ~[na:1.8.0_101]
at org.eclipse.emf.ecore.resource.impl.FileURIHandlerImpl.createInputStream(FileURIHandlerImpl.java:99) ~[org.eclipse.emf.ecore_2.8.3.v20130125-0546.jar:na]
at org.eclipse.emf.ecore.resource.impl.ExtensibleURIConverterImpl.createInputStream(ExtensibleURIConverterImpl.java:354) ~[org.eclipse.emf.ecore_2.8.3.v20130125-0546.jar:na]
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1256) ~[org.eclipse.emf.ecore_2.8.3.v20130125-0546.jar:na]
at org.eclipse.xtext.resource.impl.DefaultResourceDescription.computeExportedObjects(DefaultResourceDescription.java:73) ~[org.eclipse.xtext_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.resource.DerivedStateAwareResourceDescriptionManager$1.getLookUp(DerivedStateAwareResourceDescriptionManager.java:61) [org.eclipse.xtext_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.resource.impl.AbstractResourceDescription.getExportedObjects(AbstractResourceDescription.java:32) [org.eclipse.xtext_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.resource.DerivedStateAwareResourceDescriptionManager.internalGetResourceDescription(DerivedStateAwareResourceDescriptionManager.java:45) [org.eclipse.xtext_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.resource.impl.DefaultResourceDescriptionManager$1.get(DefaultResourceDescriptionManager.java:60) [org.eclipse.xtext_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.resource.impl.DefaultResourceDescriptionManager$1.get(DefaultResourceDescriptionManager.java:1) [org.eclipse.xtext_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.util.OnChangeEvictingCache.get(OnChangeEvictingCache.java:75) [org.eclipse.xtext.util_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.resource.impl.DefaultResourceDescriptionManager.getResourceDescription(DefaultResourceDescriptionManager.java:58) [org.eclipse.xtext_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.resource.impl.ResourceSetBasedResourceDescriptions.getResourceDescription(ResourceSetBasedResourceDescriptions.java:97) [org.eclipse.xtext_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.resource.impl.ResourceSetBasedResourceDescriptions$1$1.computeNext(ResourceSetBasedResourceDescriptions.java:61) [org.eclipse.xtext_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.resource.impl.ResourceSetBasedResourceDescriptions$1$1.computeNext(ResourceSetBasedResourceDescriptions.java:1) [org.eclipse.xtext_2.3.0.v201206120633.jar:na]
at com.google.common.collect.AbstractIterator.tryToComputeNext(AbstractIterator.java:141) [com.google.guava_10.0.1.v201203051515.jar:na]
at com.google.common.collect.AbstractIterator.hasNext(AbstractIterator.java:136) [com.google.guava_10.0.1.v201203051515.jar:na]
at com.google.common.collect.Iterators$7.computeNext(Iterators.java:643) [com.google.guava_10.0.1.v201203051515.jar:na]
at com.google.common.collect.Iterators$8.hasNext(Iterators.java:777) [com.google.guava_10.0.1.v201203051515.jar:na]
at com.google.common.collect.Iterables$3.hasNext(Iterables.java:501) [com.google.guava_10.0.1.v201203051515.jar:na]
at com.google.common.collect.Iterators$5.hasNext(Iterators.java:539) [com.google.guava_10.0.1.v201203051515.jar:na]
at org.eclipse.xtext.common.types.access.impl.IndexedJvmTypeAccess.getIndexedJvmType(IndexedJvmTypeAccess.java:64) [org.eclipse.xtext.common.types_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.common.types.access.impl.IndexedJvmTypeAccess.getIndexedJvmType(IndexedJvmTypeAccess.java:53) [org.eclipse.xtext.common.types_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.common.types.access.impl.ClasspathTypeProvider.findTypeByName(ClasspathTypeProvider.java:77) [org.eclipse.xtext.common.types_2.3.0.v201206120633.jar:na]
at org.openhab.model.script.scoping.ScriptScopeProvider.createItemFeatures(ScriptScopeProvider.java:87) [org.openhab.model.script_1.8.3.jar:na]
at org.openhab.model.script.scoping.ScriptScopeProvider.createSimpleFeatureCallScope(ScriptScopeProvider.java:64) [org.openhab.model.script_1.8.3.jar:na]
at org.eclipse.xtext.xbase.scoping.XbaseScopeProvider.createFeatureCallScope(XbaseScopeProvider.java:331) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.xbase.scoping.XbaseScopeProvider.getScope(XbaseScopeProvider.java:179) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.xbase.linking.XbaseLinkingScopeProvider.getScope(XbaseLinkingScopeProvider.java:42) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.linking.impl.DefaultLinkingService.getScope(DefaultLinkingService.java:59) [org.eclipse.xtext_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.linking.impl.DefaultLinkingService.getLinkedObjects(DefaultLinkingService.java:119) [org.eclipse.xtext_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.linking.lazy.LazyLinkingResource.getEObject(LazyLinkingResource.java:179) [org.eclipse.xtext_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.xbase.resource.XbaseResource.access$0(XbaseResource.java:1) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.xbase.resource.XbaseResource$2.exec(XbaseResource.java:239) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.xbase.resource.XbaseResource$2.exec(XbaseResource.java:1) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.util.OnChangeEvictingCache.execWithoutCacheClear(OnChangeEvictingCache.java:124) [org.eclipse.xtext.util_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.xbase.resource.XbaseResource.getEObject(XbaseResource.java:237) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getEObject(ResourceSetImpl.java:223) [org.eclipse.emf.ecore_2.8.3.v20130125-0546.jar:na]
at org.eclipse.emf.ecore.util.EcoreUtil.resolve(EcoreUtil.java:197) [org.eclipse.emf.ecore_2.8.3.v20130125-0546.jar:na]
at org.eclipse.emf.ecore.util.EcoreUtil.resolve(EcoreUtil.java:257) [org.eclipse.emf.ecore_2.8.3.v20130125-0546.jar:na]
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eResolveProxy(BasicEObjectImpl.java:1473) [org.eclipse.emf.ecore_2.8.3.v20130125-0546.jar:na]
at org.eclipse.xtext.xbase.impl.XAbstractFeatureCallImpl.getFeature(XAbstractFeatureCallImpl.java:175) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.xbase.impl.XAbstractFeatureCallImpl.eGet(XAbstractFeatureCallImpl.java:434) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.xbase.impl.XFeatureCallImpl.eGet(XFeatureCallImpl.java:224) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjectImpl.java:1011) [org.eclipse.emf.ecore_2.8.3.v20130125-0546.jar:na]
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjectImpl.java:1003) [org.eclipse.emf.ecore_2.8.3.v20130125-0546.jar:na]
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjectImpl.java:998) [org.eclipse.emf.ecore_2.8.3.v20130125-0546.jar:na]
at org.eclipse.xtext.xbase.resource.XbaseResource.trackResolution(XbaseResource.java:202) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.xbase.resource.XbaseResource.getFeature(XbaseResource.java:187) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.xbase.resource.LinkingAssumptions.getFeature(LinkingAssumptions.java:120) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.xbase.impl.FeatureCallToJavaMapping.getFeature(FeatureCallToJavaMapping.java:60) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.xbase.impl.FeatureCallToJavaMapping.getActualReceiver(FeatureCallToJavaMapping.java:44) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateAbstractFeatureCall(XbaseInterpreter.java:656) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at sun.reflect.GeneratedMethodAccessor41.invoke(Unknown Source) ~[na:na]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) ~[na:1.8.0_101]
at java.lang.reflect.Method.invoke(Unknown Source) ~[na:1.8.0_101]
at org.eclipse.xtext.util.PolymorphicDispatcher.invoke(PolymorphicDispatcher.java:291) [org.eclipse.xtext.util_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:218) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateBlockExpression(XbaseInterpreter.java:321) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[na:1.8.0_101]
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) ~[na:1.8.0_101]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:204) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at org.openhab.model.script.internal.engine.ScriptImpl.execute(ScriptImpl.java:59) [org.openhab.model.script_1.8.3.jar:na]
at org.openhab.core.scriptengine.ScriptExecutionThread.run(ScriptExecutionThread.java:44) [org.openhab.core.scriptengine_1.8.3.jar:na]
content of notification.rules (currently not in use)
/*rule "Test Notification"
Item Window_EG_WZ_W received update
sendSms("+41000000000", "dritter SMS Test")
sendBroadcastNotification("HST EG West wurde geöffnet.")
