Hi I am trying to work round a problem with the rfxcom binding which does not fully support lighting4.
I found some cheap window door contacts which output 3 signals (open, closed and tamper) but these do not get picked up by the command value.
The workround seems to be to use the RawData value but this is a long string and I just need to match part of it.
So far I have set up an Item
String garage_1 { rfxcom="<158674:RawData" }
I can output this to the log file and I can see that there is a sequence of characters which relate to the three different values.
This is an example RawData output and the 10th - 16th characters tell me the door state. The other values keep changing.
0913001E26BD2E013970
I’ve look on the drools site and I see there are commands for matches or contains but in designer it does not seem accept this.
I was hoping to do something like this:
rule "garage_1 door status"
Item garage_1 changed
if
garage_1.state contains (xyc123)
sendCommand(garage, ON)
else if
garage_1.state contains (xyc124)
sendCommand(garage, OFF)
You need to convert the .state to a string before you can use the method .contains!
if garage_1.state.toString.contains ("xyc123") {
}else if garage_1.state.toString.contains ("xyc124") {
14:00:02.145 [ERROR] [.o.m.r.i.engine.ExecuteRuleJob:57 ] - Error during the execution of rule Klima Vacation ON
java.lang.IllegalStateException: Could not invoke method: org.eclipse.xtext.xbase.lib.ObjectExtensions.operator_doubleArrow(T,org.eclipse.xtext.xbase.lib.Procedures$Procedure1) on instance: null
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:738) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._featureCallOperation(XbaseInterpreter.java:713) ~[na:na]
at sun.reflect.GeneratedMethodAccessor60.invoke(Unknown Source) ~[na:na]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[na:1.8.0_121]
at java.lang.reflect.Method.invoke(Method.java:498) ~[na:1.8.0_121]
at org.eclipse.xtext.util.PolymorphicDispatcher.invoke(PolymorphicDispatcher.java:291) ~[na:na]
at org.openhab.model.script.interpreter.ScriptInterpreter.internalFeatureCallDispatch(ScriptInterpreter.java:69) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateAbstractFeatureCall(XbaseInterpreter.java:658) ~[na:na]
at sun.reflect.GeneratedMethodAccessor53.invoke(Unknown Source) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:218) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateIfExpression(XbaseInterpreter.java:327) ~[na:na]
at sun.reflect.GeneratedMethodAccessor64.invoke(Unknown Source) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateBlockExpression(XbaseInterpreter.java:321) ~[na:na]
at sun.reflect.GeneratedMethodAccessor65.invoke(Unknown Source) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:204) ~[na:na]
at org.openhab.model.script.internal.engine.ScriptImpl.execute(ScriptImpl.java:59) ~[na:na]
at org.openhab.model.rule.internal.engine.ExecuteRuleJob.execute(ExecuteRuleJob.java:55) ~[na:na]
at org.quartz.core.JobRunShell.run(JobRunShell.java:213) [quartz-all-2.1.7.jar:na]
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:557) [quartz-all-2.1.7.jar:na]
Caused by: java.lang.IllegalArgumentException: argument type mismatch
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[na:1.8.0_121]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[na:1.8.0_121]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:729) ~[na:na]
... 29 common frames omitted
I think you meant
Weather_Temperature.state >= 23
“>=” is “greater than or equal to”
“=>” is the operator_doubleArrow, probably not what you intended
