- Platform information:
- Hardware: CPUArchitecture/RAM/storage rPi 3
- openHAB version: openhabian 2.2
Issue of the topic: I got multiple rollershutter items, which are perfectly useable in BasicUI and Android APP.
We do have some fly screen doors which tend to fly open, when there is a lot of wind, so in the past, we always used the Homematic Control to trigger a program to set the rollershutters to close for 2% so the doors where “locked in”.
Now I switched to openhab and wanted to create a similar button in my sitemap, but as soon as I define that button, the rollershutter buttons turn from the “UP,X,DOWN” (where UP and DOWN are arrow keys) to a slider, which is not useable.
As soon as I uncomment the lines below the comments
//Sturmschutz Erker and //Schlitzlüften Erker
, the rollershutters become unusable.
Does anyone have an idea, how this happens?
.items file
//Rollladen Erker Links
Rollershutter Rollladen_ErkerLinks "Rollladen Erker Links [%d%%]" (gRolllaeden,gErdgeschoss,gWohnzimmer,gRolllaedenErker,gRolllaedenErkerSpecial)["Lighting"] { channel="homematic:HM-LC-Bl1-FM:704745df:NEQ1688388:1#LEVEL" }
//Rollladen Erker Mitte
Rollershutter Rollladen_ErkerMitte "Rollladen Erker Mitte [%d%%]" (gRolllaeden,gErdgeschoss,gWohnzimmer,gRolllaedenErker,gRolllaedenErkerSpecial) ["Lighting"]{ channel="homematic:HM-LC-Bl1-FM:704745df:NEQ1557297:1#LEVEL" }
//Rollladen Erker Rechts
Rollershutter Rollladen_ErkerRechts "Rollladen Erker Rechts [%d%%]" (gRolllaeden,gErdgeschoss,gWohnzimmer,gRolllaedenErker,gRolllaedenErkerSpecial)["Lighting"] { channel="homematic:HM-LC-Bl1-FM:704745df:NEQ1557012:1#LEVEL" }
//Gruppe Rolllaeden Erker
Group:Rollershutter:OR(UP, DOWN, STOP) gRolllaedenErkerSpecial "Rollläden Erker [%d%%]" <rollershutter> (gRolllaeden)["Lighting"]
//Sturmschutz Erker
Switch Rolllaeden_Sturmschutz_Switch "Sturmschutz"["Lighting"] icon="wind"
Switch Rolllaeden_Schlitzlueften_Switch "Schlitzlüften"["Lighting"] icon="flow"
.sitemap
Switch item=Rollladen_ErkerLinks label="Rollladen Erker Links [%d%%]"
Switch item=Rollladen_ErkerMitte label="Rollladen Erker Mitte [%d%%]"
Switch item=Rollladen_ErkerRechts label="Rollladen Erker Rechts [%d%%]"
**Switch item=Rolllaeden_Sturmschutz_Switch label="Sturmschutz Erker" icon="wind"**
** Switch item=Rolllaeden_Schlitzlueften_Switch label="Lüften Erker" icon="flow"**
.rule file
//Regeln
//Sturmschutz fuer die Fenster im Erker
rule "Sturmschutz"
Item Rolllaeden_Sturmschutz_Switch received command
if (receivedCommand == ON) {
sendCommand(gRolllaedenErkerSpecial,2)
else {
sendCommand(gRolllaedenErkerSpecial,0)
//Lüften der Fenster im Erker
rule "Schlitzlueften"
Item Rolllaeden_Schlitzlueften_Switch received command
sendCommand(gRolllaedenErkerSpecial,95)
else {
sendCommand(gRolllaedenErkerSpecial,100)
