Rule MQTT temperature > Tradfrii Switch
Hello.
I want to build a rule so that Tradfrii Switch triggered using MQTT temperature measurement.
Unfortunately I don’t know completely how to set the rule triggered by MQTT
I want to control the temperature in my boiler.
If the water temperature is equal or higher than 59 degrees Celsius - the Tradfrii switch should turn off
and
If the water temperature is equal or lower than 50 degrees Celsius - the Tradfrii switch should turn on
Snippets of my configuration are below:
.things
    Bridge mqtt:broker:HomeMqttBroker [
        host="10.10.102.200",
        port="1883",
        secure=false,
        username="name",
        password="password",
        clientID="openhab"
    Thing topic myBasementEsp32
        Channels:
            Type number : Temperature [stateTopic="basement/hotwater", refresh=5 ]
.items
// MQTT
// READ
Number HotWaterTemperature {channel="mqtt:topic:HomeMqttBroker:myBasementEsp32:Temperature"}
.rules ???
I built up reading posts and documentation
rule "Hot water pump off"
    Item HotWaterTemperature changed
    if (ControlOutlet5.state == ON)
    ControlOutlet1.sendCommand(OFF)
Unfortunately, I do not know how to set temperatures that interest me?
Thank you in advance for any help
I’d do the following
You need to use {} for if statements.
You can change it to one rule.
The sleep for 500ms makes sure you read the latest value from the temperature.
rule "Hot water pump rule"
    Thread::sleep(500)
    if (HotWaterTemperature.state > 50 && ControlOutlet5.state == ON) {
    else if (HotWaterTemperature.state < 30 && ControlOutlet5.state == ON) {
        ControlOutlet1.sendCommand(ON)
Now that you showed me this - everything is very simple and obvious !!! However, without your help he would not do it alone.
Thank you very much
Uh, it’s just changed, you know that because it’s the rule trigger condition.
No need to wait here, just take that delay out.
OK - thanks
