Rule not testing item state correctly
Platform Rpi4, OH3
I have tried to port a working rule from OH2 but it is not behaving in the same way.
I have a switch (which determines whether the rule is active) which is in state ON:
This is the first few rows from the rule. It gets past “triggered1” but never gets to “triggered2”.
rule "TPIRuleBR"
    Item BackRoomSetPoint changed
    logInfo ("TPIBackRoom  ", "triggered1")
    if (BackRoomHeatingLogic.state == ON)
        logInfo ("TPIBackRoom  ", "triggered2")
The equivalent rule / switch works fine in OH2. What am I doing wrong?
Log out what the Item state is inside the rule.
Changed code to:
rule "TPIRuleBR"
    logInfo ("TPIBackRoom  ", "switch state is: "+ BackRoomHeatingLogic.state)
Output to log is now:
2021-01-08 09:01:29.390 [INFO ] [nhab.core.model.script.TPIBackRoom  ] - switch state is: ON
2021-01-08 09:01:29.375 [INFO ] [openhab.event.ItemCommandEvent      ] - Item 'BackRoomSetPoint' received command 17.5
2021-01-08 09:01:29.383 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'BackRoomSetPoint' changed from 17 to 17.5
i.e. still doesn’t seem to be testing the state properly.
BackRoomHeatingLogic is for sure a Switch Item? It’s not a String or a Dimmer or something like that?
What happens if you us toString?
if (BackRoomHeatingLogic.state.toString == "ON")
Hi. Yes it does work correctly if, as you say, I convert to and test the state as a string. I will have a play and see if I can replicate a simple rule generated directly in the GUI.
I have now realised that i set up the “switch” as a String type item. Changed it to a Switch type item and the code now works correctly. Thanks for your help again.
