Hello all
- Platform information:
- Hardware: Raspberry Pi 4 Model B Rev 1.1
- OS: openhabian
- openHAB version: 3.0.1 - Release Build
If I change a item, the rule will not work correct. Here I show you my steps, at the beginnig everything is fine:
Item file:
Switch SW_Test
String Str_Test // { expire="5s,Noooo" }
Rule file:
rule "Test Rule"
Item SW_Test changed
Str_Test.sendCommand("Yesss")
After SW_Test changed I got these Log:
23:39:19.316 [INFO ] [del.core.internal.ModelRepositoryImpl] - Loading model 'Test.rules'
23:39:25.161 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'SW_Test' received command ON
23:39:25.168 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'SW_Test' changed from OFF to ON
23:39:25.176 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Str_Test' received command Yesss
Til now OK
And then I change the item Str_Test to:
String Str_Test { expire="5s,Noooo" }
In Test Rule nothing changed and the Log look like this:
23:44:15.368 [INFO ] [del.core.internal.ModelRepositoryImpl] - Loading model 'Test.items'
23:46:06.284 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'SW_Test' received command OFF
23:46:06.289 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'SW_Test' changed from ON to OFF
Why does not change the item Str_Test?
Now I must change something in the rule file that Test.rules is loading und after that it works fine.
rule "Test Rule" // tutututut
23:51:48.124 [INFO ] [del.core.internal.ModelRepositoryImpl] - Loading model 'Test.rules'
23:51:55.023 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'SW_Test' received command ON
23:51:55.031 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'SW_Test' changed from OFF to ON
23:51:55.042 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Str_Test' received command Yesss
23:52:00.304 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Str_Test' changed from Yesss to Noooo
That means whenever I change a item I must reload all rule files? It can’t really be, can it?
I allready clean the cache and reboot the Raspberry. I also replaced sendCommand with postUpdate but the same behaviour
Regards
Steffen
