May I ask somebody to help me check my rule and to correct it?
I made some adjustments, especially with the [|] and () and {}, as VisualStudio reported some errors. For now it seems to be working, but I am not sure with the timer still:
var Timer timerKodiabschalten = null
rule “Kodi Stromzufuhr abschalten wenn ungenutzt”
Item Verbrauch_Kodi changed
if(Verbrauch_Kodi.state < 2){
if (timerKodiabschalten===null) {
timerKodiabschalten = createTimer(now.plusMinutes (10), [ |
Kodi_Energiezufuhr.sendCommand(OFF)
else if(Verbrauch_Kodi.state > 2){
timerKodiabschalten?.cancel
timerKodiabschalten = null // cancel timer if power consumption raises
rule "Kodi Stromzufuhr abschalten wenn ungenutzt"
logInfo("test", "My rule begins")
logInfo("test", "key value " + Verbrauch_Kodi.state.toString)
logInfo("test", "starting timer")
logInfo("test", "timer begins")
logInfo("test", "timer aborting")
} else {
logInfo("test", "unexpectedly here")
Have a think about edge cases.
What happens if Item state is exactly 2? I think you can do away with else-if() and just use else for cancelling.
What happens after 10 minutes is up the first time? Can you ever create a new timer later? Hint - you need the timer code block to set its own handle to null before exiting, to clear the way for a later run.
Thanks. I’ll try with some logging.
For the unlikely case of consumption being exactly 2 I added >= to the cancel condition.
One last question regarding:
Isn’t the timerKodiabschalten = null line meant to do so? Or do you mean I should include this line also in the first condition where the timer actually gets used? If so, where would I have to add it?
I tested the as in my last post for several on and off cycles and it seems it is working. But I’ll improve it with your tips.
Yes. You will see this technique used in most of the timer examples.
Generally at the end of the timer’s execution block, set the timerKodiabschalten handle back to null, so that it becomes easy for subsequent runs of the rule to detect “there is no timer now”.
That would allow a timer execution to finish without doing anything, if power over threshold, but also not nulling the handle.
When the timer finishes, whatever the outcome, you’ll want to clear the way for the next time.
